Bacnet Write block
Hi
I am new to Node-Red and am trying to use the bacnet node. I can get the read to work and the write to work. What I can't figure out is how to put a value into the write block. To clarify (I hope) the write block works when I use the value in the properties box. Can anyone help?
Hi Andrew and welcome to the forum.
I have never used Bacnet nodes, But most inputs for nodes can be sent in msg.payload, or you may be able to set input to msg.property name. Can you show a image of the bacnet write node config. Also what does the sidebar help text say?
The may also be examples in menu import > examples.
This topic may help
Hi
Many thanks for the prompt response. The topic is exactly my problem I was just hoping for a simpler solution!
I have spent my career using function block programming to programme Siemens Air conditioning controls so have never needed to code.
I guess I’ll just have to play around with it. Thanks again.
