Hi. below is the dataURI that is worked in dashboard v1 but not in v2.
data:image/png;base64,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...
Below is the code in the template node
<div>
<img src="{{msg.payload}}" alt="QR Code">
</div>
Why?
you have to use the explicit base64 call in src (below my is working for me in DB2) ..just replace mymoon with whatever you have
<img height="70px" :title="mymoon_phase" :src="`data:image/jpg;base64,${mymoon}`"
do you mean like this? still not working for me
<template>
<div>
<h1>Base64 Image Example</h1>
<img
height="70px"
:title="imageTitle"
:src="imageSrc"
alt="My Base64 Image"
</div>
</template>
<script>
export default {
data() {
return {
imageTitle: 'Your Image Title',
imageSrc: 'data:image/png;base64,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...'
</script>
I tried like this also did not work
<template>
<div>
<div>
<img src ="{{count}}">
<p style="color: red">Last Payload: {{ count }}</p>
</div>
</div>
</template>
<script>
export default {
data() {
// define variables available component-wide
// (in <template> and component functions)
return {
count: 0,
watch: {
// watch for any changes of "count"
msg: function () {
if (this.msg.topic === 'counter') {
this.count = this.msg.payload
</script>
the result just like this
In my example
- I do load the picture into msg.payload.astro.moon_link .. and do the base64 convert
- transfer msg.payload.astro.moon_link to this.mymoon
- display the icon in my vcard template
<v-card class="mx-0" width="100%" color="black">
<template v-slot:append>
<img height="70px" :title="mymoon_phase" :src="`data:image/jpg;base64,${mymoon}`" @click="expand = !expand"/>
</template>
</v-card>
The syntax in Dashboard 2 is slightly different. When binding attributes, you use the following syntax:
:src="myVariable"
You can see it in the documentation here.
