Pushing a base64 encoded image to dashboard D2
Hi folks,
I wanted to continue on another discussion, but seems that nowadays discussions are closed within 2 weeks already...
Anyway I am trying to migrate my old dashboard to D2, but I am stuck with this simple flow to push a base64 encoded image and show it:
[{"id":"2f477a1223387dfb","type":"http request","z":"320444070953412f","name":"","method":"GET","ret":"bin","paytoqs":"ignore","url":"https://upload.wikimedia.org/wikipedia/commons/thumb/6/6f/A-maze-ing-Laughter-001_BMK.jpg/800px-A-maze-ing-Laughter-001_BMK.jpg?20140208145224","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"basic","senderr":false,"headers":[],"x":330,"y":480,"wires":[["c51f3f4c566a5ab9"]]},{"id":"c51f3f4c566a5ab9","type":"base64","z":"320444070953412f","name":"Encode","action":"","property":"payload","x":500,"y":480,"wires":[["7335e86fba8a34a4"]]},{"id":"7335e86fba8a34a4","type":"ui-template","z":"320444070953412f","group":"2980b33865f3a94a","page":"","ui":"","name":"","order":0,"width":0,"height":0,"head":"","format":"<template>\n    <img :src=\"`data:image/jpg;base64,${msg.payload}`\" />\n</template>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":660,"y":480,"wires":[[]]},{"id":"782a888e9537f0c1","type":"inject","z":"320444070953412f","name":"load image","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":480,"wires":[["2f477a1223387dfb"]]},{"id":"2980b33865f3a94a","type":"ui-group","name":"Snapshots","page":"8fe11f0a1785825d","width":"6","height":"1","order":-1,"showTitle":true,"className":"","visible":"true","disabled":"false"},{"id":"8fe11f0a1785825d","type":"ui-page","name":"Cameras","ui":"be29745a6e568f30","path":"/page6","icon":"cctv","layout":"grid","theme":"092547d34959327c","order":-1,"className":"","visible":"true","disabled":"false"},{"id":"be29745a6e568f30","type":"ui-base","name":"UI Name","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false},{"id":"092547d34959327c","type":"ui-theme","name":"Theme Name","colors":{"surface":"#ffffff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"}}]
I tried a couple of different templates:
<template>
    <img src="data:image/jpg;base64,{{msg.payload}}" />
</template>
And:
<template>
    <img :src="`data:image/jpg;base64,${msg.payload}`" />
</template>
But none of these seem to work for me:
I had some errors in my developer console, that the src (containing an unresolved msg.payload) could not be loaded. And I see the unresolved msg.payload also there:
When I clear my developer console and inject the image (or another image) again, I don't see anything appearing in my console log. So it looks like me that the next messages are not being handled. But not sure at all about that...
The weird thing is that after a page refresh the image suddenly shows up:
Does anybody know what I am doing wrong?
I am currently wondering if VueJs and I will ever become friends. I really hope it won't become my second enemy next to CSS. Seems that my brain doesn't like technologies that are doing lots of magic behind the scenes....
Thanks!!
Bart
I can't get to my laptop to decipher why your second template isn't working.
The first one won't work as you have {{ }} inside the attribute value, only need to do this in the HTML templating. For attributes, use : as you have in the second template and treat its content as Javascript.
I do have this example I sent in our Discord recently which may help:
flow.json (3.5 KB)
Hi Joe,
Please don't tell me that you have smuggled your laptop in your suitcase between your pyjama's, so your lady wouldn't see it...
Enjoy your holidays!!!!!!!!!!!!!!!!!!!!!!!!!
BTW your flow works. Will try tonight if I can manage to use it for my ip cam snapshot images. Or if somebody else with some VueJs knowledge sees what I am doing wrong, then they can share there knowledge of course....
All from my phone, don't like seeing people stuck on things that I've built!
Worked first time for me Bart.
SQLiteStudio_x8NL0HLKpk
I didnt have the base64 node so simply used a function node instead (should make zero difference)
msg.payload = Buffer.from(msg.payload).toString('base64')
As you can see from the gif, deploy -> inject - > tada
Hey Steve,
That is weird. Will try again this evening.
Thanks for testing my flow!!!
Enjoy your sunday...
Hey @Steve-Mcl,
Yes indeed it worked fine now.
The only difference now is that I do a full deploy (due to some other issues I had tonight), instead of only deploying the modified nodes.
Not sure whether that has caused it this morning.
So case closed...
