Basic Javascript Function concatenation [SOLVED]
Hi.
I'm struggling in understand what's wrong in this concatenation.
I'm failin in concatenate this object[1], using this function[2].
Nothing is coming out.
Thanks in advance for your answer.
This is the code
[1]
{"specie":"siamese","animal":"cat","age":5,"name":"Pippi","vax":true,"vaxDate":3}
[2]
let string1 = 'This ';
let animal = msg.payload.animal;
let string2 = ' is called ';
let name = msg.payload.name;
//let age = Number(msg.payload.age);
//let data = Number(msg.payload.vaxDate);
//let anni = age - data;
let final = string1;// + animal + string2 + name;
msg.payload.text = final;
Hi @vongomben
You need to add return msg to the end of the code to pass the message on.
oops.
Thanks.
That was monday afternoon probably.
ciao!
