Hi ,
I am a newbie to node-red and I am trying to understand the usages of each node . I couldn't find any examples around batch node to understand the use case where the node fits in . I read through the brief definition and the 3 modes of operation which technically able to understand but on a realtime use case I am not able to find a story.
When I tried using the batch node with debug i could see the output from batch node but I was in an assumption that each batch is having specific unique id. But the response I am observing is all having same id (message id).
Flow
Inject node --> Function node(code give below) --> batch node(sequence by number of message ,set as 2) --> Debug node
Function node code
for(var i=0; i<4 ;i++){
node.send({payload:i});
Could you please share any examples or link directing to the usage of a batch node.
Regards
Arun
