Beginner - Sending mulitple AT commands in sequence to a serial interface (raspberry pi with USB dongle)
Hi .. I am new to both Node-RED and the forum..
I am kind of stuck and hoping someone can send me in the right direction -
Setup - Raspberry Pi 3 - LTE USB dongle
Due to lack of internet in the house I am setting the node red up - I would like to send SMS trough a USB dongle..
And I am able to now. By first using a function to send payload
var num = "+45xxxxxxxx";
var at_cmd = "AT+CMGS=\""+num+"\"";
msg.payload=at_cmd+"\r";
Then insert a delay for 2 seconds . and then using function to send the second payload
var sms_msg = "Temperature low";
msg.payload=sms_msg+"\x1A";
This is working fine.
But when I would like to add a second number to send a SMS to in parallel with the one above - then I am not in control of the sending of AT commands to the USB interface - and ending up getting ether errors or mixing the at commands - so i'll include the "at_cmd+" from sequence1 as text in the sequence2 SMS
The question - what would be best practice - set some kind of flag in the sequence1 to stop sequence2 - or a switch node before the serial interface?
BR Jan Eriksen
Hi and welcome.
I am confused by what you mean "to send a SMS to a parallel with the one above".
parallel is the problem here. Could you elaborate on what you mean there?
Doing this would be one way of doing what you want.
I hope you can understand what I am meaning.
The inject node is there to simulate a message arriving and to get things going.
the first function node does the first bit you mentioned and the first debug node goes to the code to do the
The next function node will send the second part.
Then the last one does the third command you are wanting to do.
This is my flow now - and in short.
Inject - reads the temperature on the 2 sensors every 5 sec. and if the state is belowe 24 C on Temp1 sensor - 2 different phones gets the sms "Temp1 Low" and thats okay now, when i got the delay in. But If both Temp1 and Temp2 changes state at the same time, or when I deploy - the state is set at the same time, then the AT commands is mixed up from the 2 flow.
First part of the flow
        "id": "ab3d9378cba2a69c",
        "type": "tab",
        "label": "Flow 4",
        "disabled": false,
        "info": "",
        "env": []
        "id": "456ac1f426159150",
        "type": "sensor-ds18b20",
        "z": "ab3d9378cba2a69c",
        "name": "Temp1",
        "topic": "",
        "sensorid": "28-021317ba0faa",
        "timer": "3",
        "repeat": false,
        "x": 330,
        "y": 200,
                "9894e78d2cafdb69",
                "762fd6988e76c6f8",
                "7c8cf407622df33d"
        "id": "9894e78d2cafdb69",
        "type": "ui_gauge",
        "group": "3b4b41a454fdbea4",
        "order": 0,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "title": "Temp1",
        "label": "C",
        "format": "{{value}}",
        "min": 0,
        "max": "40",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 550,
        "y": 280,
        "id": "762fd6988e76c6f8",
        "type": "ui_chart",
        "order": 1,
        "width": 0,
        "height": 0,
        "label": "Temp1",
        "chartType": "line",
        "legend": "false",
        "xformat": "HH:mm:ss",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "removeOlderPoints": "",
        "removeOlderUnit": "3600",
        "cutout": 0,
        "useOneColor": false,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "useDifferentColor": false,
        "className": "",
        "x": 550,
        "y": 320,
        "id": "7c8cf407622df33d",
        "type": "switch",
        "name": "Switch between On and Off",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "gt",
                "v": "24",
                "vt": "num"
                "t": "lte",
                "v": "24",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 580,
        "y": 200,
                "35d874550817f0d3"
                "dfd71c249d6aec9e"
        "id": "cd4009e040bb100a",
        "type": "rpi-gpio out",
        "pin": "21",
        "set": "",
        "level": "0",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 1140,
        "y": 180,
        "id": "dfd71c249d6aec9e",
        "type": "change",
        "name": "ON",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "1",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 810,
        "y": 240,
                "e07c1a5de4c88d0a",
                "cd4009e040bb100a",
                "d5113d3e059ddd67"
        "id": "35d874550817f0d3",
        "type": "change",
        "name": "OFF",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "0",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 810,
        "y": 200,
                "cd4009e040bb100a",
                "e07c1a5de4c88d0a",
                "d5113d3e059ddd67"
        "id": "daed55a025e13af7",
        "type": "function",
        "name": "Send to +45xxxxxxxx",
        "func": "var num = \"+45xxxxxxxx\";\nvar at_cmd = \"AT+CMGS=\\\"\"+num+\"\\\"\"; \n\n\n\nmsg.payload=at_cmd+\"\\r\";\n//msg.payload.msg =msg.payload.message;\n\nreturn msg;",
        "outputs": "1",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1440,
        "y": 240,
                "e77004374c606002",
                "13f10f748a517135"
        "id": "e8b146c8bbeb51e3",
        "type": "serial out",
        "name": "Serail-Out",
        "serial": "93485f7d.0073f",
        "x": 2360,
        "y": 340,
        "id": "0421b41ac42c9932",
        "type": "function",
        "name": "Send to +45yyyyyyyy",
        "func": "var num = \"+45yyyyyyyy\";\nvar at_cmd = \"AT+CMGS=\\\"\"+num+\"\\\"\"; \n\n\n\nmsg.payload=at_cmd+\"\\r\";\n//msg.payload.msg =msg.payload.message;\n\nreturn msg;",
        "outputs": "1",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1960,
        "y": 360,
                "ce31756f4f28f90e",
                "13f10f748a517135"
        "id": "e07c1a5de4c88d0a",
        "type": "trigger",
        "name": "Trigger on low",
        "op1": "1",
        "op2": "0",
        "op1type": "str",
        "op2type": "str",
        "duration": "0",
        "extend": false,
        "overrideDelay": false,
        "units": "ms",
        "reset": "0",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 1160,
        "y": 240,
                "daed55a025e13af7"
        "id": "fa2cb9762b48bad0",
        "type": "function",
        "func": "var num = \"+45xxxxxxxx\";\nvar at_cmd = \"AT+CMGS=\\\"\"+num+\"\\\"\"; \n\nmsg.payload=at_cmd+\"\\r\";\n//msg.payload.msg =msg.payload.message;\n\nreturn msg;",
        "outputs": "1",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1440,
        "y": 460,
                "6202c61b75518bed",
                "8c85e9641002b16a"
        "id": "6433a70de4096dfd",
        "x": 2360,
        "y": 560,
        "id": "b1576d3428389c16",
        "type": "function",
        "name": "Message - Temp1 Normal",
        "func": "var sms_msg = \"Temp1 Normal\";\n\nmsg.payload=sms_msg+\"\\x1A\";\n//msg.payload.msg =msg.payload.message;\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 2010,
        "y": 520,
                "7aa45a64475a9327",
                "8c85e9641002b16a"
        "id": "6202c61b75518bed",
        "type": "delay",
        "name": "2 sec. delay",
        "pauseType": "delay",
        "timeout": "2",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1730,
        "y": 520,
                "b1576d3428389c16"
        "id": "36da162b38e559e5",
        "type": "function",
        "func": "var num = \"+45yyyyyyyy2\";\nvar at_cmd = \"AT+CMGS=\\\"\"+num+\"\\\"\"; \n\nmsg.payload=at_cmd+\"\\r\";\n//msg.payload.msg =msg.payload.message;\n\nreturn msg;",
        "outputs": "1",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 2000,
        "y": 580,
                "51cdee925e4a9515",
                "8c85e9641002b16a"
        "id": "0835e74319b64d94",
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 2010,
        "y": 640,
                "8c85e9641002b16a"
        "id": "51cdee925e4a9515",
        "type": "delay",
        "timeout": "2",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1730,
        "y": 640,
                "0835e74319b64d94"
        "id": "7aa45a64475a9327",
        "type": "delay",
        "timeout": "2",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1730,
        "y": 580,
                "36da162b38e559e5"
        "id": "d5113d3e059ddd67",
        "type": "trigger",
        "name": "Trigger on normal",
        "op1": "0",
        "op2": "0",
        "op1type": "str",
        "op2type": "str",
        "duration": "0",
        "extend": false,
        "units": "ms",
        "reset": "1",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 1170,
        "y": 300,
                "fa2cb9762b48bad0"
        "id": "4b5a646321a1da5c",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "5",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payloadType": "date",
        "x": 150,
        "y": 200,
                "456ac1f426159150"
        "id": "78f49080734fbfdd",
        "type": "function",
        "name": "Message - Temp1 Low",
        "func": "var sms_msg = \"Temp1 low\";\n\nmsg.payload=sms_msg+\"\\x1A\";\n//msg.payload.msg =msg.payload.message;\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1960,
        "y": 300,
                "fec72d9e6be55e7f",
                "13f10f748a517135"
        "id": "9429809b41a30d45",
        "type": "function",
        "name": "Message - Temp1 low",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1960,
        "y": 420,
                "13f10f748a517135"
        "id": "ce31756f4f28f90e",
        "type": "delay",
        "name": "3 sec. delay",
        "timeout": "3",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1730,
        "y": 420,
                "9429809b41a30d45"
        "id": "e77004374c606002",
        "type": "delay",
        "timeout": "3",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1730,
        "y": 300,
                "78f49080734fbfdd"
        "id": "fec72d9e6be55e7f",
        "type": "delay",
        "name": "3 sec delay",
        "timeout": "3",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1730,
        "y": 360,
                "0421b41ac42c9932"
        "id": "13f10f748a517135",
        "type": "function",
        "name": "Do nothing",
        "func": "\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 2350,
        "y": 240,
                "e8b146c8bbeb51e3",
                "ba32d65c15d97588"
        "id": "8c85e9641002b16a",
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 2350,
        "y": 440,
                "6433a70de4096dfd",
                "821dc5a62e90b779"
        "id": "ba32d65c15d97588",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 2570,
        "y": 240,
        "id": "821dc5a62e90b779",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 2570,
        "y": 440,
        "id": "3b4b41a454fdbea4",
        "type": "ui_group",
        "name": "Temp1",
        "tab": "dbc3af9fe5f50809",
        "order": 1,
        "disp": false,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "93485f7d.0073f",
        "type": "serial-port",
        "serialport": "/dev/ttyUSB3",
        "serialbaud": "9600",
        "databits": "8",
        "parity": "none",
        "stopbits": "1",
        "waitfor": "",
        "newline": "\\n\\r",
        "bin": "false",
        "out": "char",
        "addchar": "false",
        "responsetimeout": ""
        "id": "dbc3af9fe5f50809",
        "type": "ui_tab",
        "name": "Floes",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
Second part of the flow
        "type": "tab",
        "label": "Flow 4",
        "disabled": false,
        "info": "",
        "env": []
        "id": "058e3fb12774f792",
        "name": "Temp2",
        "topic": "",
        "sensorid": "28-030997790878",
        "timer": "3",
        "repeat": false,
        "x": 290,
        "y": 180,
                "00879db046f76ce5",
                "944efa2e5fab7809",
                "0880415b2616e7b2"
        "id": "00879db046f76ce5",
        "type": "ui_gauge",
        "group": "ba9be29e7ac01f9d",
        "order": 0,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "title": "Temp2",
        "label": "C",
        "min": 0,
        "max": "40",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 470,
        "y": 280,
        "id": "944efa2e5fab7809",
        "type": "ui_chart",
        "order": 1,
        "width": 0,
        "height": 0,
        "label": "Temp2",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "cutout": 0,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "className": "",
        "x": 470,
        "y": 320,
        "id": "cef813c19f3b2b94",
        "type": "serial in",
        "name": "Serial-In",
        "x": 2220,
        "y": 660,
                "b797db790e9a41ac"
        "id": "b797db790e9a41ac",
        "type": "debug",
        "active": false,
        "console": "false",
        "complete": "false",
        "x": 2390,
        "y": 660,
        "id": "a18fd8dcfd6e2fd2",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "5",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "x": 110,
        "y": 180,
                "058e3fb12774f792"
        "id": "0880415b2616e7b2",
        "type": "switch",
        "name": "Skift",
        "rules": [
                "t": "gt",
                "v": "24",
                "vt": "num"
                "t": "lte",
                "v": "24",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 470,
        "y": 180,
                "8a0d379a440dc794"
                "1cb03c72e7d9e7ca"
        "id": "1cb03c72e7d9e7ca",
        "type": "change",
        "name": "ON",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "1",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 730,
        "y": 220,
                "3fb5baad1fbccae1",
                "84832452f6a2f648"
        "id": "8a0d379a440dc794",
        "type": "change",
        "name": "OFF",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "0",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 730,
        "y": 180,
                "3fb5baad1fbccae1",
                "84832452f6a2f648"
        "id": "bf56e432530b0a88",
        "type": "function",
        "outputs": "1",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1300,
        "y": 180,
                "aa88b39a2c0408bb",
                "07e5f1ccb3ac737f"
        "id": "b90d60c466ae5f6a",
        "type": "function",
        "name": "Message - Temp2 low",
        "func": "var sms_msg = \"Temp2 low\";\n\nmsg.payload=sms_msg+\"\\x1A\";\n//msg.payload.msg =msg.payload.message;\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1940,
        "y": 240,
                "281c130f6d424f13",
                "07e5f1ccb3ac737f"
        "id": "aa88b39a2c0408bb",
        "type": "delay",
        "name": "6 sec. delay",
        "timeout": "6",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1670,
        "y": 240,
                "b90d60c466ae5f6a"
        "id": "6aa1a4e756d0a0e8",
        "type": "function",
        "func": "var num = \"+45yyyyyyyy\";\nvar at_cmd = \"AT+CMGS=\\\"\"+num+\"\\\"\"; \n\nmsg.payload=at_cmd+\"\\r\";\n//msg.payload.msg =msg.payload.message;\n\nreturn msg;",
        "outputs": "1",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1940,
        "y": 300,
                "5e8c57fbe6778fdd",
                "07e5f1ccb3ac737f"
        "id": "fa634561f9e48bce",
        "type": "function",
        "name": "Message Temp2 low",
        "func": "var sms_msg = \"Temp2 Low\";\n\nmsg.payload=sms_msg+\"\\x1A\";\n//msg.payload.msg =msg.payload.message;\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1940,
        "y": 360,
                "07e5f1ccb3ac737f"
        "id": "3fb5baad1fbccae1",
        "type": "trigger",
        "op1": "1",
        "op2": "0",
        "op1type": "str",
        "op2type": "str",
        "duration": "0",
        "extend": false,
        "units": "ms",
        "reset": "0",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 1020,
        "y": 180,
                "bf56e432530b0a88"
        "id": "05d0e91c59b6de09",
        "type": "function",
        "outputs": "1",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1340,
        "y": 440,
                "d100461d08710984",
                "964e64c7e23327fb"
        "id": "11fc35ce1893d4dc",
        "x": 2240,
        "y": 540,
        "id": "7b630b778a3e6fe2",
        "type": "function",
        "name": "Message - Temp2 Normal",
        "func": "var sms_msg = \"Temp2 Normal\";\n\nmsg.payload=sms_msg+\"\\x1A\";\n//msg.payload.msg =msg.payload.message;\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1910,
        "y": 480,
                "944faccbb2a2d20f",
                "964e64c7e23327fb"
        "id": "94d68a51ab63167c",
        "type": "function",
        "outputs": "1",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1900,
        "y": 540,
                "8acc4828f5888dc4",
                "964e64c7e23327fb"
        "id": "d4a52b2bd6b2212b",
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1910,
        "y": 600,
                "964e64c7e23327fb"
        "id": "84832452f6a2f648",
        "type": "trigger",
        "op1": "0",
        "op2": "0",
        "op1type": "str",
        "op2type": "str",
        "duration": "0",
        "extend": false,
        "units": "ms",
        "reset": "1",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 1030,
        "y": 240,
                "05d0e91c59b6de09"
        "id": "281c130f6d424f13",
        "type": "delay",
        "timeout": "3",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1670,
        "y": 300,
                "6aa1a4e756d0a0e8"
        "id": "5e8c57fbe6778fdd",
        "type": "delay",
        "timeout": "3",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1670,
        "y": 360,
                "fa634561f9e48bce"
        "id": "d100461d08710984",
        "type": "delay",
        "name": "2 sek forsinkelse",
        "timeout": "2",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1650,
        "y": 480,
                "7b630b778a3e6fe2"
        "id": "944faccbb2a2d20f",
        "type": "delay",
        "timeout": "2",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1650,
        "y": 540,
                "94d68a51ab63167c"
        "id": "8acc4828f5888dc4",
        "type": "delay",
        "timeout": "2",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1650,
        "y": 600,
                "d4a52b2bd6b2212b"
        "id": "9da459aec61619a0",
        "x": 2260,
        "y": 280,
        "id": "07e5f1ccb3ac737f",
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 2270,
        "y": 180,
                "9da459aec61619a0",
                "3a127e0eaf9415bb"
        "id": "964e64c7e23327fb",
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 2230,
        "y": 440,
                "11fc35ce1893d4dc",
                "832a8afac877e7c6"
        "id": "3a127e0eaf9415bb",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 2510,
        "y": 180,
        "id": "832a8afac877e7c6",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 2510,
        "y": 440,
        "id": "ba9be29e7ac01f9d",
        "type": "ui_group",
        "name": "Temp2",
        "order": 2,
        "disp": false,
        "width": "6",
        "collapse": false,
        "className": ""
        "databits": "8",
        "parity": "none",
        "stopbits": "1",
        "waitfor": "",
        "bin": "false",
        "out": "char",
        "addchar": "false",
        "type": "ui_tab",
        "name": "Floes",
        "disabled": false,
        "hidden": false
Ok, when first deployed there is a conflict.
Why not add a delay for reading Temp2 so it happens at a different time than Temp1?
I'm not sure how you posted the flow/s but .....
AFAIK, you should be able to post the entire flow in one block - if what your screen shot shows is the whole thing.
But - please - before you post it replace the nodes that get the temperature and replace them with simply a function node that sends a number value with a nominal value.
Otherwise it won't work on my machine. (My: anyone who loads it wanting to help)
If you have a section of flow that must only have one message flowing through it at any one time then one way to solve that is to use node-red-contrib-semaphore. I have used that and it works well.
