Best way to save variables across node-red restarts?
Dear Node-redders (are you called like that?)
Just wanted to ask what the best way is to preserve a variable and it's state defined in the .js file of a node. Got some websocket listeners I want to start listening for them again after node-red restarts. How can I do that?
Thank You
Hansi
Hi @hansimeister
If this is outside the basic context of a Nodes config, just use your own mechanism,
and you need it to be accessed only by your module - just roll your own mechanisms - at least that's what I do.
Create a folder if it does not exist.
module.exports = function(RED) {
    function Init(config) {
        const stateDir = path.join(RED.settings.userDir, 'super-node-state')
        if (!fs.existsSync(stateDir)) {
            fs.mkdirSync(stateDir)
Store JSON files in there and read/write/parse them whenever you need, such as checking if there is a state you can use during start up :wink:
Many ways, but this is what I do, as the state objects I need to save/read are very complex and some do not use JSON at all.
EDIT
There is also the Node Context its self (but I don't use it)
https://nodered.org/docs/creating-nodes/context
var nodeContext = this.context();
you need to make sure the Users Node RED is set to use localfilesystem (I think) if you want the values to survive a reboot/restart - again I think, I just use my own mech that I have full control over
https://nodered.org/docs/api/context
Certainly use your own if you don't need/want users of the node to have control. If you do want them to have control, you can use Node-RED's own context methods. I do that, for example, in UIBUILDER's cache node which lets users have full control over whether they want to persist the cache or even make it available to other nodes.
In the past, others have suggested using an MQTT broker (i.e. mosquito) that supports "retained messages" -- so when an mqtt in node connects to a topic it receives the last message that was sent to that topic.
I have not tried this myself, but it sounds pretty elegant and bullet-proof. Searching this forum for "mqtt retain context" yields many interesting threads, like this one: Access to mqtt retained messages
Edit: in my pre-caffeine state, I failed to notice the category is "Developing Nodes" -- so this is probably not relevant to what you are doing
:upside_down_face:
I like "node-reddites" -- sounds like "Luddites" that have discovered a simple tool for building everything without needing to embrace more complex emerging technologies... ;*)
