Has anyone used the BigFile module (node-red-contrib-bigfile)? And, if so, do you know how to set the start and end options in order to read a range of the file instead of the entire file? I'm passing in a message with the filename and start and end, but can't get it to actually use the start and end.
This is an example of what I've tried for my input message. BigFile does recognize the filename.
Looking at the BigFile code (and ultimately, the BigLib code), it appears the property should be 'config' and not 'options'. However, it still doesn't work.
