Hi, about 3 days ago get to the second output from Bigtimer 1 or 0, but now only " "...
Do you have it too?
Yes, that seems to be a change introduced in the latest version of bigtimer.
I do not know if it's a bug.
However it is not documented on the author's website or in the node help.
You cannot raise issues on gitHub.
The author says "I do not plan to spend any more time hunting through Node-Red forums for BigTimer queries".
I suggest you take a look at node-red-contrib-cron-plus to see if it works for you.
node-red-contrib-cron-plus is well supported in the forum, so if you get stuck... ask away
Thanx, Cron plus is good node, but I need now Bigtimer.
