Dear reader, I am just beginning with Node-red (5.0.4, npm 11.15.0) and have some trouble with the following. All the BLE messages I can receive with the BLE Scanner result in a lot of info and I would like to make it more readable. I am already able to 'write' the data (JSON) into a MySQL table but as a single message. I would like to put the different items per mess in a viewable table. e.g. id in column id, address in column address and if possible in a ui-table with a point and click option (fase 2)
I already have:
start and stop option for the BLE scanner
JSON parser
simple INSERT (SQL)
and a DB connection to a table
Unless you actually need to process the resulting data with SQL queries or the resulting data is very large (e.g. 10,000+ entries), using a DB is almost certainly overkill.
You can tell Node-RED to provide a file-based context store (see the docs) and use that to store your data as JSON instead.
You need it in that format anyway in order to display it as a table in Dashboard or UIBUILDER.
