Block User Input till it is time
I have raised a github feature request for DB2, but this will take some more time I believe. meanwhile I would like help to somehow get this done, as I am really stuck.
I just need a way to block user inputs (click/key press) till it is time.
ui-spinner was a perfect solution for me, but it is for old dashboard.
I'm not too familiar with DB2, but if you could indulge me.....
In the old one, you could disable items if you sent a message with msg.enable == true or false.
(ok, the enable may not be exact either. But I hope you understand the meaning.)
It is documented.
So.... Looking at your question.
Have all the graphical things laid out and there.
Then, have a bit of code that - at a given time - sends an ENABLE message to them.
This will make them usable.
Before that time a DISABLE command was sent and you couldn't use any of the graphical things.
Just a thought.
You know you can simply use the overlay and the circular progress components of vuetify in a template node right?! :wink:
explorer_DQVcdylIeJ
[{"id":"3fed1246ce96d5be","type":"ui-template","z":"3aca33261d046b21","group":"","page":"","ui":"972a512aa841474c","name":"FlowFuse Overlay Spinner","order":0,"width":0,"height":0,"head":"","format":"<template>\n    <v-overlay\n        :model-value=\"isBusy\"\n        class=\"align-center justify-center\"\n        :scrim=\"overlayColor\"\n        :opacity=\"overlayOpacity\"\n        persistent\n    >\n        <div class=\"d-flex flex-column align-center justify-center\">\n            <v-progress-circular color=\"primary\" indeterminate size=\"72\" :width=\"8\"></v-progress-circular>\n            <div v-if=\"busyMessage\" class=\"mt-4 text-h6 text-center\">{{ busyMessage }}</div>\n        </div>\n    </v-overlay>\n</template>\n\n<script>\n    // An overlay with spinner and options, by Steve-Mcl (FlowFuse inc)\n    export default {\n        computed: {\n            payload () {\n                let p = this.msg?.payload ?? {}\n                if (typeof p === \"boolean\") { return {} }\n                if (typeof p === \"string\") {\n                    p = { message: p }\n                }\n                return p\n            },\n            isBusy() {\n                return this.msg?.topic === \"show\"\n            },\n            busyMessage() {\n                if (this.isBusy && this.payload.message) {\n                    return this.payload.message\n                }\n                return ''\n            },\n            overlayColor() {\n                const scrim = this.payload.color ?? this.payload.scrim\n                if (this.isBusy && (typeof scrim === \"string\")) {\n                    return scrim\n                }\n                return 'grey darken-3'\n            },\n            overlayOpacity() {\n                if (typeof this.payload.opacity === \"number\") {\n                    return Math.min(1, Math.max(0, this.payload.opacity))\n                }\n                return 0.6 // Default opacity if not specified\n            }\n        }\n    }\n</script>\n<style>\n    .v-overlay__content {\n        flex-direction: column; /* To stack spinner and message vertically */\n    }\n</style>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"widget:ui","className":"","x":600,"y":140,"wires":[[]]},{"id":"0f4d4bbaab53f06e","type":"inject","z":"3aca33261d046b21","name":"just show","props":[{"p":"topic","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"show","payload":"true","payloadType":"bool","x":200,"y":140,"wires":[["3fed1246ce96d5be"]]},{"id":"57d3aa3f5b98fe2a","type":"inject","z":"3aca33261d046b21","name":"show with simple message","props":[{"p":"topic","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"show","payload":"Please wait...","payloadType":"str","x":250,"y":180,"wires":[["3fed1246ce96d5be"]]},{"id":"7d9c433d681e2028","type":"inject","z":"3aca33261d046b21","name":"hide","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"hide","x":190,"y":100,"wires":[["3fed1246ce96d5be"]]},{"id":"5397a333a026035c","type":"inject","z":"3aca33261d046b21","name":"show with messsage, opacity and color","props":[{"p":"topic","vt":"str"},{"p":"payload.message","v":"Purple, less transparent!","vt":"str"},{"p":"payload.opacity","v":"0.8","vt":"num"},{"p":"payload.color","v":"purple","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"show","x":290,"y":220,"wires":[["3fed1246ce96d5be"]]},{"id":"972a512aa841474c","type":"ui-base","name":"My Dashboard","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","showReconnectNotification":true,"notificationDisplayTime":5,"showDisconnectNotification":true,"allowInstall":false}]
