Boot warning msg
What does the msg below mean? I'm not using a serialport node:
[node-red-node-serialport/serialport] Error: libnode.so.64: cannot open shared object file: No such file or directory
TIA
Starting as a systemd service.
23 Nov 08:39:44 - [info]
Welcome to Node-RED
23 Nov 08:39:44 - [info] Node-RED version: v1.2.5
23 Nov 08:39:44 - [info] Node.js  version: v12.19.1
23 Nov 08:39:44 - [info] Linux 5.4.77-v7+ arm LE
23 Nov 08:39:45 - [info] Loading palette nodes
23 Nov 08:39:47 - [info] Dashboard version 2.24.0 started at /ui
23 Nov 08:39:48 - [warn] ------------------------------------------------------
23 Nov 08:39:48 - [warn] [node-red-node-serialport/serialport] Error: libnode.so.64: cannot open shared object file: No such file or directory
23 Nov 08:39:48 - [info] Settings file  : /home/pi/.node-red/settings.js
23 Nov 08:39:48 - [info] Context store  : 'default' [module=memory]
23 Nov 08:39:48 - [info] User directory : /home/pi/.node-red
23 Nov 08:39:48 - [warn] Projects disabled : editorTheme.projects.enabled=false
Look in the Manage Palette option under the hamburger menu. If it shows installed and not in use then remove it.
If it shows in use then look in Configuration Nodes to see if you have any unused serial config nodes and delete them. Then you should be able to remove it.
This' interesting. I cannot find any leftover code anywhere.
Go to Meniu, Manage palette, Nodes
