Guys, I have broke my node-red. I have installed few new packages and it won't start. this is full log from startup. I have already reinstalled NR, that didn't help. Any ideas? Thank you
Welcome to Node-RED
7 Dec 22:35:05 - [info] Node-RED version: v0.19.5
7 Dec 22:35:05 - [info] Node.js version: v8.12.0
7 Dec 22:35:05 - [info] Linux 4.14.71-v7+ arm LE
7 Dec 22:35:06 - [info] Loading palette nodes
7 Dec 22:35:13 - [info] Dashboard version 2.11.0 started at /ui
7 Dec 22:35:14 - [warn] ------------------------------------------------------
7 Dec 22:35:14 - [warn] [node-red-contrib-mi-devices/xiaomi-yeelight] Error: /home/bednarz/.node-red/node_modules/node-red-contrib-mi-devices/dist/nodes/yeelight/index.html does not exist
7 Dec 22:35:14 - [warn] [node-red-contrib-mydash/mydash] TypeError: "file" argument must be a non-empty string (line:9)
7 Dec 22:35:14 - [warn] [node-red-contrib-xiaomi-devices/xiaomi-ht] Type already registered
7 Dec 22:35:14 - [warn] [node-red-contrib-xiaomi-devices/xiaomi-magnet] Type already registered
7 Dec 22:35:14 - [warn] [node-red-contrib-xiaomi-devices/xiaomi-motion] Type already registered
7 Dec 22:35:14 - [warn] [node-red-contrib-xiaomi-devices/xiaomi-switch] Type already registered
7 Dec 22:35:14 - [warn] [node-red-contrib-xiaomi-devices/xiaomi-socket] Type already registered
7 Dec 22:35:14 - [warn] [node-red-contrib-xiaomi-devices/xiaomi-socket-wifi] Type already registered
7 Dec 22:35:14 - [warn] [node-red-contrib-xiaomi-devices/xiaomi-configurator] Type already registered
7 Dec 22:35:14 - [info] Settings file : /home/bednarz/.node-red/settings.js
7 Dec 22:35:14 - [info] Context store : 'default' [module=memory]
7 Dec 22:35:14 - [info] User directory : /home/bednarz/.node-red
7 Dec 22:35:14 - [warn] Projects disabled : editorTheme.projects.enabled=false
7 Dec 22:35:14 - [info] Flows file : /home/bednarz/.node-red/flows_raspberrypi.json
7 Dec 22:35:14 - [info] Server now running at http://127.0.0.1:1880/
Detected device with identifier 130275447 types Set { 'placeholder', 'miio' } model undefined
Detected device with identifier 53865017 types Set { 'placeholder', 'miio' } model undefined
your credentials.
7 Dec 22:35:14 - [info] Waiting for missing types to be registered:
7 Dec 22:35:14 - [info] - powershell
Detected device with identifier 130275356 types Set { 'placeholder', 'miio' } model undefined
Detected device with identifier 57595030 types Set { 'placeholder', 'miio' } model undefined
Detected device with identifier 87149866 types Set { 'placeholder', 'miio' } model undefined
Detected device with identifier 78253705 types Set { 'placeholder', 'miio' } model undefined
Detected device with identifier 57795237 types Set { 'placeholder', 'miio' } model undefined
Detected device with identifier 87148356 types Set { 'placeholder', 'miio' } model undefined
