My Node_RED on Raspberry Pi doesn't start anymore.
What can I do?
Log:
7 Mar 10:32:05 - [info]
Welcome to Node-RED
7 Mar 10:32:05 - [info] Node-RED version: v0.19.5
7 Mar 10:32:05 - [info] Node.js version: v8.15.1
7 Mar 10:32:05 - [info] Linux 4.14.98-v7+ arm LE
7 Mar 10:32:06 - [info] Loading palette nodes
7 Mar 10:32:12 - [info] Dashboard version 2.10.1 started at /ui
7 Mar 10:32:13 - [warn] ------------------------------------------------------
7 Mar 10:32:13 - [warn] [node-red-contrib-join/join] Type already registered
7 Mar 10:32:13 - [info] Settings file : /home/pi/.node-red/settings.js
7 Mar 10:32:13 - [info] HTTP Static : /home/pi
7 Mar 10:32:13 - [info] Context store : 'default' [module=memory]
7 Mar 10:32:13 - [info] User directory : /home/pi/.node-red
7 Mar 10:32:13 - [warn] Projects disabled : editorTheme.projects.enabled=false
7 Mar 10:32:13 - [info] Flows file : /home/pi/.node-red/flows_RasPi3.json
7 Mar 10:32:13 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
7 Mar 10:32:13 - [info] Starting flows
7 Mar 10:32:14 - [info] Started flows
7 Mar 10:32:14 - [info] [sqlitedb:e16c76ef.539d58] opened sqlite/nieuws.db ok
7 Mar 10:32:14 - [info] [sqlitedb:457cf60e.f0cf48] opened sqlite/nodered.db ok
7 Mar 10:32:14 - [info] [mqtt-broker:ac303ca4.001af] Connected to broker: mqtt://192.168.0.118:1883
7 Mar 10:32:16 - [error] [function:Set maanstand] TypeError: Cannot read property 'ageOfMoon' of undefined
7 Mar 10:32:21 - [red] Uncaught Exception:
7 Mar 10:32:21 - TypeError: Cannot read property 'code' of undefined
at /home/pi/.node-red/node_modules/node-red-contrib-broadlink-control/nodes/RMNode.js:92:143
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Unit entered failed state.
nodered.service: Failed with result 'exit-code'.
