Buffer-parser parsing 32bitBE fails
I have trouble to parse 32bit Value using buffer-parser node
This is the Input:
[ff,ff,ef,a0]
SyntaxError: Unexpected token f in JSON at position 2
My expected Value is:
-4192
Thanks for help
Joseph
We are good, but I'm afraid we are not mind readers :slight_smile:
You will have to share the data going into the buffer-parser and how you have it setup (at minimum) for us to help you.
For a buffer input you have to convert into decimal numbers.
Then your buffer node does what you expect:
Or use strings ["0xff","0xff","0xef","0xa0"] ...
Thank you Steve,
I have seen, the Problem was the inject-node sending the error (not the 'buffer parser')
Cu Joseph
