Buffer parser to reverse
I converted the data that came with the buffer parser node to string, but it was reversed in binary, how can I fix this?
Try setting swap 16
I don't understand, can you write in more detail?
Open the buffer. Parser settings and look for a property named swap. Select the option swap 16. Deploy and try again.
worked thank you
