How to convert 16 bits into a word / integer
Need the reverse of this so dashboard switches can effect a control device.
Have looked - any ideas?
Thanks - Hans
Hi @HansZnarf you need provide more information about!! can you share us your flow?
I think this node does what you want:
Cannot take credit for this flow.
flows (4).json (645 Bytes)
Looking for a block that reverses this process. Take 16 bit and structure it into an Int.
Did you have a look at the node I suggested?
Kind of like this
You were informed in your previous post that the buffer-parser node can convert in both directions.
