I have a TCPIP node that outputs as follows;
If I use a function node to do msg.payload.toString() I get;
But if I then use a JSON node I get this;
Position 1444 in the buffer is this;
Ive tried all sorts and just cant find anything that works.
Any pointers would be appreciated.
Thx
From the looks of your msg.payload string there's a return character at the end of the string.
Try stripping that out in your function node before the JSON node.
it's the 00 at the end that may be the issue - but yes - either way - stripping it off with .substr is probably the easiest way to go.
Many thanks for the prompt responses.
var str = msg.payload.toString();
msg.payload = str.substr(0,1443);
Works like a charm!
.....until payload length changes then it fails. Changed function to;
msg.payload = str.replace(/\0/,"");
just fr completeness you can also use .slice - which will take negative numbers to count from the end so
msg.payload = msg.payload.toString().slice(0,-1);
