Building "queue" and Processing by timestamp?
I want to build create/store "object"/ messages with in a flow, give them an individual timestamp
and process these messages/"object" when the time (of timestamp) reached.
Here: specially I want to create "alarm noification" with different attributs and a specific time in future, the notification should be processed.
Any hint/idea how this could be best implemented ?
Thank you very much
Regards
Thorsten
You can do this with Cron-plus node. It is fully programmable via command messages. You add and remove time based, Cron based or solar based events.
Here is a simple dashboard demo
Also checkout the example flows it ships with (ctrl+i --> examples)
Thank you very much.
I will try it.
Regatds
