Button Group on small screen
This button group is size 6x1 and in landscape on my Android phone (Firefox) it looks like this
In portrait though it's like this. There is the merest hint of a (vertical?) scroll bar which does not show in the screen capture, but I can find no way to get to the missing two buttons, and the rounded end after the green icon implies that the entire widget is displayed.
Is there any way to access the right hand buttons?
Should there be a visible indication that this widget is not fully displayed - even a horizontal scrollbar?
By default it should wrap like this
CSS override somewhere?
Ah.
Yes, actually it has your nice CSS from button-group-nodes-no-change-of-states only with more garish colours.
Doesn't seem to make a difference when I disable that CSS though.
And you are up to date with the dashboard version?
1.22.1 yes.
Find this element and let's see..
I don't know how to do that on my phone, but on my PC that line is identical to what you show except I don't see == $0
(No colours because your CSS disabled)
Make a new screenshot, leave my CSS in, and show lines a little bit above the target element just like I did.
Oh, no need. There's another bug. Firefox doesn't wrap.
Add those to the CSS
.btn-grp-colored-icons button{
    min-height: var(--widget-row-height);
    height: auto;
.btn-grp-colored-icons .v-btn-group{
    height: unset !important;
Or if you don't want it to wrap on small screens and the content fits nicely (and remains usable when squeezed)
    height: auto;
    min-width: unset;
    padding: 0 0 0 0;
    width: 100%;
    flex-wrap: nowrap !important;
That is outstanding, thank you @hotNipi.
It works well for text labels too, within reason. I like that the available space is allocated to buttons according to each label length.
I think that 6 buttons across a phone screen in portrait is about right, they have roughly the same size as desktop icons.
Still fails if I use provocatively long labels or combine text and icons, would be nice if it could somehow indicate the display is not complete. Even so, it's better than wrapping to a second line IMHO.
This solution or something like it should be the default behaviour. Any thoughts @joepavitt ?
I think no.
By default it should wrap. Otherwise not fitting situation (which will happen almost always) is an issue. And it should have paddings surrounding the readable content because of web standards. And that brings the need of the wrapping closer.
What maybe is reasonable is to have tickbox to turn wrapping off.
You also need to watch out for accessibility issues. Might not be a problem for home use but would certainly be an issue for public use, especially in the EU and UK where there are laws covering accessibility of websites.
Buttons for touch devices need to be a minimum size.
Just to extend this, the initial request for the wrapping come from someone that had 96 buttons in a single button group... so I think wrapping is a sensible default here.
A button group of 6 buttons which does not easily fit into the group width:
Firefox
Chrome
Edge
  • Is this a bug in Firefox or in the dashboard?
  • If it's Firefox, is it something that the dashboard should provide a work-around for?
  • Are there any plans to alleviate this?
  • Are there other modern browsers showing this problem?
  • @hotNipi has shown a CSS work-around. Should this be the default for this node? Does it have side effects on some browsers?
Someone should test MacOS/Safari and also Android and iOS default browser apps.
Edge, Chrome (yuck), Vivaldi, Brave, .... all use Chromium with the v8 engine. So they should all be the same.
Some clarifications...
Someone should test MacOS/Safari (WebKit renderer (aka the new IE)) and also Android (slightly streamlined version of Blink) and iOS default browser apps (also WebKit like it's big brother)
Edge, Chrome, Vivaldi, Brave, Opera, etc... all use the Blink renderer. So they should all be the same.
