Buttons on DB2 not responding to input signals (code stolen from another topic)
Another topic talked about buttons in ui-builder which I don’t use, but I liked the buttons so I stole the code from @Paul-Reed github page and tried to adapt to DB2. Got pretty far but the buttons don’t respond to input changes. After a heated exchange with chatgpt I am asking for a little help. Flow below. I should note at this point it’s trying to see what I can learn but if I can get this working I’d like to make some changes to my dashboards.
        "id": "08632d912a50eeea",
        "type": "function",
        "z": "0c10944b4a49d66c",
        "name": "set flow array",
        "func": "\n//Mode  0 random, 1 off, 2 on\n\nif (msg.topic == \"light1\"){\n    flow.set(\"light1\",msg.payload);\n}\nif (msg.topic == \"light2\") {\n    flow.set(\"light2\",msg.payload);\n}\nif (msg.topic == \"light3\") {\n    flow.set(\"light3\", msg.payload);\n}\n\nmsg={};\n\n\n\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 630,
        "y": 100,
        "id": "ab7b770d7439735f",
        "type": "ui-template",
        "group": "eab230110ad3b180",
        "page": "",
        "ui": "",
        "name": "Timer1",
        "order": 5,
        "width": "3",
        "height": "2",
        "head": "",
        "format": "<template>\n  <main>\n    <v-col>\n      <v-row>\n        <!-- Light 1 -->\n        <section class=\"wrap-row\">\n          <button class=\"status-button\" @click=\"light1\">\n            <div class=\"indicator\" :style=\"{ backgroundColor: indicatorColor1 }\"></div>\n            <span>{{ isOn1 ? 'Light1 On' : 'Light1 Off' }}</span>\n          </button>\n        </section>\n\n        <!-- Light 2 -->\n        <section class=\"wrap-row\">\n          <button class=\"status-button\" @click=\"light2\">\n            <div class=\"indicator\" :style=\"{ backgroundColor: indicatorColor2 }\"></div>\n            <span>{{ isOn2 ? 'Light2 On' : 'Light2 Off' }}</span>\n          </button>\n        </section>\n\n        <!-- Light 3 -->\n        <section class=\"wrap-row\">\n          <button class=\"status-button\" @click=\"light3\">\n            <div class=\"indicator\" :style=\"{ backgroundColor: indicatorColor3 }\"></div>\n            <span>{{ isOn3 ? 'Light3 On' : 'Light3 Off' }}</span>\n          </button>\n        </section>\n      </v-row>\n    </v-col>\n  </main>\n</template>\n\n<script>\nexport default {\n  data() {\n    return {\n      isOn1: false,\n      isOn2: false,\n      isOn3: false,\n      msg: {} // placeholder for external updates\n    };\n  },\n  computed: {\n    indicatorColor1() {\n      return this.isOn1 ? 'limegreen' : 'blue';\n    },\n    indicatorColor2() {\n      return this.isOn2 ? 'limegreen' : 'blue';\n    },\n    indicatorColor3() {\n      return this.isOn3 ? 'limegreen' : 'blue';\n    }\n  },\n  watch: {\n    msg: {\n    deep: true,\n      handler(newVal) {\n        if (!newVal || !newVal.topic) return;\n    \n        if (newVal.topic === \"light1\") {\n          this.isOn1 = !!newVal.payload; // force boolean\n          this.send({ topic: \"light1\", payload: this.isOn1 });\n        }\n        if (newVal.topic === \"light2\") {\n          this.isOn2 = !!newVal.payload;\n        }\n        if (newVal.topic === \"light3\") {\n          this.isOn3 = !!newVal.payload;\n        }\n      },\n    },\n  },\n\n\n  methods: {\n    light1() {\n      this.isOn1 = !this.isOn1;\n      this.send({ topic: \"light1\", payload: this.isOn1 });\n    },\n\n    light2() {\n      this.isOn2 = !this.isOn2;\n      this.send({ topic: \"light2\", payload: this.isOn2 });\n    },\n\n    light3() {\n      this.isOn3 = !this.isOn3;\n      this.send({ topic: \"light3\", payload: this.isOn3 });\n    },\n  },\n};\n</script>\n\n<style scoped>\n.status-button {\n  display: flex;\n  align-items: center;\n  background-color: var(--surface4);\n  border: 1px solid var(--text3);\n  border-radius: var(--border-radius);\n  padding: 6px 10px;\n  margin-right: 0.3em;\n  font-family: var(--font-family);\n  color: black;\n  height: var(--control-height);\n  width: fit-content;\n  cursor: pointer;\n  transition: box-shadow 0.4s, transform 0.2s;\n}\n\n.status-button:active {\n  transform: scale(0.98);\n  box-shadow: 0 0 5px rgba(0, 0, 0, 0.2);\n}\n\n.indicator {\n  width: 0.5em;\n  height: 2em;\n  margin-right: 0.5em;\n  border-radius: 0.5em;\n  transition: background-color 0.3s;\n}\n\n.wrap-row {\n  display: flex;\n  flex-wrap: wrap;\n  gap: 0.2em;\n  align-items: flex-start;\n  justify-content: flex-start;\n}\n\n:root {\n  --control-height: 3em;\n  --surface4: #f0f0f0;\n  --text3: #ccc;\n  --border-radius: 0.5em;\n  --font-family: Arial, sans-serif;\n  --text-color: #333;\n  --font-size-base: 1rem;\n}\n</style>\n",
        "storeOutMessages": true,
        "passthru": false,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 430,
        "y": 80,
                "08632d912a50eeea",
                "d7a2d9a92aaf2133"
        "id": "06acf90d0ab38e63",
        "group": "",
        "page": "1e8c695c2252935b",
        "ui": "",
        "order": 0,
        "width": 0,
        "height": 0,
        "head": "",
        "format": "\n\n<style>\n    .root {}\n\n    .container {\n        display: flex;\n        justify-content: center;\n        align-items: center;\n        width: 90px;\n        height: 80px;\n        /* Adjust height as needed */\n        background-color: black;\n        border-top: 3px solid #6689a1;\n        border-bottom: 3px solid #6689a1;\n        border-left: 3px solid #6689a1;\n        border-right: 3px solid #6689a1;\n    }\n\n    .containerTop {\n        display: flex;\n        justify-content: center;\n        align-items: center;\n        width: 270px;\n        height: 25px;\n        /* Adjust height as needed */\n        background-color: black;\n        color: white;\n        font-size: 12px;\n        text-align: center;\n        border-bottom: 2px solid #dd7f00;\n        border-top: 3px solid #6689a1;\n        border-left: 3px solid #6689a1;\n        border-right: 3px solid #6689a1;\n    }\n\n    .containerTopTwo {\n        display: flex;\n        justify-content: center;\n        align-items: center;\n        width: 135px;\n        height: 25px;\n        /* Adjust height as needed */\n        background-color: black;\n        color: white;\n        font-size: 12px;\n        text-align: center;\n        border-bottom: 2px solid #dd7f00;\n        border-top: 3px solid #6689a1;\n        border-left: 3px solid #6689a1;\n        border-right: 3px solid #6689a1;\n    }\n\n    .containerTopThree {\n        display: flex;\n        justify-content: center;\n        align-items: center;\n        width: 90px;\n        height: 25px;\n        /* Adjust height as needed */\n        background-color: black;\n        color: white;\n        font-size: 12px;\n        text-align: center;\n        border-bottom: 2px solid #dd7f00;\n        border-top: 3px solid #6689a1;\n        border-left: 3px solid #6689a1;\n        border-right: 3px solid #6689a1;\n    }\n\n    .containerBottom {\n        display: flex;\n        justify-content: center;\n        align-items: center;\n        width: 270px;\n        color: white;\n        font-size: 12px;\n        text-align: center;\n        height: 25px;\n        /* Adjust height as needed */\n        background-color: black;\n        border-top: 3px solid #6689a1;\n        border-bottom: 3px solid #6689a1;\n        border-left: 3px solid #6689a1;\n        border-right: 3px solid #6689a1;\n    }\n\n    .containerOne {\n        display: flex;\n        justify-content: center;\n        align-items: center;\n        width: 270px;\n        height: 40px;\n        /* Adjust height as needed */\n        background-color: black;\n        border-top: 3px solid #6689a1;\n        border-bottom: 3px solid #6689a1;\n        border-left: 3px solid #6689a1;\n        border-right: 3px solid #6689a1;\n        //font-size: 40px;\n        font-family: \"Times New Roman\", Times, serif;\n        font-style: normal;\n    }\n\n    .containerTwo {\n        display: flex;\n        justify-content: center;\n        align-items: center;\n        width: 135px;\n        height: 80px;\n        /* Adjust height as needed */\n        background-color: black;\n        border-top: 3px solid #6689a1;\n        border-bottom: 3px solid #6689a1;\n        border-left: 3px solid #6689a1;\n        border-right: 3px solid #6689a1;\n    }\n\n    .containerTime {\n        display: flex;\n        justify-content: center;\n        align-items: center;\n        width: 270px;\n        height: 40px;\n        /* Adjust height as needed */\n        background-color: black;\n        border-top: 3px solid #dd7f00;\n        border-bottom: 3px solid #dd7f00;\n        border-left: 3px solid #dd7f00;\n        border-right: 3px solid #dd7f00;\n    }\n\n    .containerTimeOne {\n        display: flex;\n        justify-content: center;\n        align-items: center;\n        width: 270px;\n        height: 40px;\n        /* Adjust height as needed */\n        background-color: black;\n        border-top: 3px solid #6689a1;\n        border-bottom: 3px solid #6689a1;\n        border-left: 3px solid #6689a1;\n        border-right: 3px solid #6689a1;\n        font-size: 80em;\n        font-family: \"Times New Roman\", Times, serif;\n        font-style: normal;\n    }\n\n    .box {\n        width: 25px;\n        /* Adjust box width as needed */\n        height: 80px;\n        /* Adjust box height as needed */\n        display: flex;\n        justify-content: center;\n        align-items: center;\n    }\n\n    .centered-button {\n        padding: 10px 20px;\n        color: white;\n        font-size: 16px;\n        cursor: pointer;\n    }\n\n    .button {\n        display: flex;\n        width: 75px;\n        padding-top: 2px;\n        border-top: 5px;\n        background-color: grey;\n        /* Default background color */\n        color: white;\n        font-size: 12px;\n        border: none;\n        cursor: pointer;\n    }\n\n    .active {\n        background-color: green;\n        /* Changed background color when active */\n    }\n\n    .a1 {\n        background-color: black;\n        justify-content: center;\n        text-align: center;\n        height: 25px !important;\n        width: 140px !important;\n        margin-top: 5px;\n        margin-bottom: 1px;\n        margin-left: 5px;\n        margin-right: 5px;\n        font-size: 16px;\n        color: #6689a1;\n        padding-bottom: 4px;\n        border-bottom: 2px solid #dd7f00;\n        border-top: 2px solid #6689a1;\n        border-left: 2px solid #6689a1;\n        border-right: 2px solid #6689a1;\n    }\n\n    .a2 {\n        background-color: grey;\n        justify-content: center;\n        align-items: center;\n        text-align: center;\n        height: 50px !important;\n        width: 100px !important;\n        margin-top: 1px;\n        margin-bottom: 5px;\n        margin-left: 5px;\n        margin-right: 5px;\n        font-size: 16px;\n        color: #6689a1;\n        padding-bottom: 2px;\n        border-bottom: 2px solid #6689a1;\n        border-top: 2px solid #6689a1;\n        border-left: 2px solid #6689a1;\n        border-right: 2px solid #6689a1;\n    }\n</style>",
        "passthru": false,
        "templateScope": "page:style",
        "className": "",
        "x": 430,
        "y": 40,
        "id": "d7a2d9a92aaf2133",
        "type": "debug",
        "name": "debug 1",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "targetType": "full",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 620,
        "y": 40,
        "id": "367664da6938bc0a",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "light1",
        "payload": "true",
        "payloadType": "bool",
        "x": 100,
        "y": 80,
                "ab7b770d7439735f",
                "e4a19c927380d807"
        "id": "e4a19c927380d807",
        "type": "debug",
        "name": "debug 2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "x": 280,
        "y": 120,
        "id": "eab230110ad3b180",
        "type": "ui-group",
        "name": "3 state",
        "width": 6,
        "height": 1,
        "order": -1,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false",
        "groupType": "default"
        "id": "1e8c695c2252935b",
        "type": "ui-page",
        "name": "New Buttons",
        "ui": "929358b9b68de19a",
        "path": "/page3",
        "icon": "home",
        "layout": "grid",
        "theme": "a539e4afb8f63f3f",
        "breakpoints": [
                "name": "Default",
                "px": "0",
                "cols": "3"
                "name": "Tablet",
                "px": "576",
                "cols": "6"
                "name": "Small Desktop",
                "px": "768",
                "cols": "9"
                "name": "Desktop",
                "px": "1024",
                "cols": "12"
        "order": -1,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "929358b9b68de19a",
        "type": "ui-base",
        "name": "My Dashboard",
        "path": "/dashboard",
        "appIcon": "",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false,
        "headerContent": "page",
        "navigationStyle": "default",
        "titleBarStyle": "default",
        "showReconnectNotification": true,
        "notificationDisplayTime": 1,
        "showDisconnectNotification": true,
        "allowInstall": true
        "id": "a539e4afb8f63f3f",
        "type": "ui-theme",
        "name": "Default Theme",
        "colors": {
            "surface": "#000000",
            "primary": "#000000",
            "bgPage": "#000000",
            "groupBg": "#000000",
            "groupOutline": "#ffffff"
        "sizes": {
            "density": "default",
            "pagePadding": "12px",
            "groupGap": "12px",
            "groupBorderRadius": "4px",
            "widgetGap": "12px"
        "id": "90bc21fd4342754b",
        "type": "global-config",
        "env": [],
        "modules": {
            "@flowfuse/node-red-dashboard": "1.24.2"
