Calculate how many hours fireplace burned in a day
Hey All,
I have a Rocket Mass Heater with a thermocouple sensor. I'm trying to report how many hours per day fire is burning.
Something like if the temp rises over 300 drop a timestamp. When the temp drops below 300 set a timestamp. Then calculate the time in between. There will be several fires throughout the day. Then at midnight reset the number and begin again.
I found this library but not sure how to use it; no documentation
How can I calculate hours burned per day?
Rich
Not a lot to help with that readme, lol.
Here is a simple flow that will take payload, if over 300 it sets a on timestamp, when 300 or below it sets off timestamp and calculates difference in minutes, you can adjust in flow the temp and convert to any time output you wish.
Hope it helps
[{"id":"ead55e9bed9f1a42","type":"inject","z":"bf569dbfc3bc07ed","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"200","payloadType":"num","x":190,"y":320,"wires":[["676ec415cd12ade3"]]},{"id":"676ec415cd12ade3","type":"change","z":"bf569dbfc3bc07ed","name":"","rules":[{"t":"set","p":"burn","pt":"msg","to":"$$.payload > 300 ? \"on\" : \"off\"","tot":"jsonata"},{"t":"set","p":"timestamp","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":300,"wires":[["49c26890a6fe0dde"]]},{"id":"c863ae53012dd9d8","type":"inject","z":"bf569dbfc3bc07ed","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"400","payloadType":"num","x":190,"y":280,"wires":[["676ec415cd12ade3"]]},{"id":"49c26890a6fe0dde","type":"rbe","z":"bf569dbfc3bc07ed","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":510,"y":300,"wires":[["c48cf7b557492ca5"]]},{"id":"c48cf7b557492ca5","type":"join","z":"bf569dbfc3bc07ed","name":"","mode":"custom","build":"object","property":"timestamp","propertyType":"msg","key":"burn","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":630,"y":300,"wires":[["19e5e8e6e3b7580d"]]},{"id":"19e5e8e6e3b7580d","type":"switch","z":"bf569dbfc3bc07ed","name":"","property":"burn","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":330,"y":360,"wires":[["5d62c80531f8eadf"]]},{"id":"5d62c80531f8eadf","type":"change","z":"bf569dbfc3bc07ed","name":"","rules":[{"t":"set","p":"burnMinutes","pt":"msg","to":"($$.timestamp.off - $$.timestamp.on)/60000","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":360,"wires":[["e6297bcf996a280a"]]},{"id":"e6297bcf996a280a","type":"debug","z":"bf569dbfc3bc07ed","name":"debug 344","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"burnMinutes","statusType":"msg","x":590,"y":400,"wires":[]}]
You can do it in hours also and save output to context then once a day grab the total and delete ready for next day.
[{"id":"c863ae53012dd9d8","type":"inject","z":"bf569dbfc3bc07ed","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"400","payloadType":"num","x":190,"y":280,"wires":[["676ec415cd12ade3"]]},{"id":"676ec415cd12ade3","type":"change","z":"bf569dbfc3bc07ed","name":"","rules":[{"t":"set","p":"burn","pt":"msg","to":"$$.payload > 300 ? \"on\" : \"off\"","tot":"jsonata"},{"t":"set","p":"timestamp","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":300,"wires":[["49c26890a6fe0dde"]]},{"id":"ead55e9bed9f1a42","type":"inject","z":"bf569dbfc3bc07ed","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"200","payloadType":"num","x":190,"y":320,"wires":[["676ec415cd12ade3"]]},{"id":"49c26890a6fe0dde","type":"rbe","z":"bf569dbfc3bc07ed","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":510,"y":300,"wires":[["c48cf7b557492ca5"]]},{"id":"c48cf7b557492ca5","type":"join","z":"bf569dbfc3bc07ed","name":"","mode":"custom","build":"object","property":"timestamp","propertyType":"msg","key":"burn","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":630,"y":300,"wires":[["19e5e8e6e3b7580d"]]},{"id":"19e5e8e6e3b7580d","type":"switch","z":"bf569dbfc3bc07ed","name":"","property":"burn","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":330,"y":360,"wires":[["5d62c80531f8eadf"]]},{"id":"5d62c80531f8eadf","type":"change","z":"bf569dbfc3bc07ed","name":"","rules":[{"t":"set","p":"burnHours","pt":"msg","to":"$sum([$flowContext(\"burn_sum\")]) + ($$.timestamp.off - $$.timestamp.on)/3600000","tot":"jsonata"},{"t":"set","p":"burn_sum","pt":"flow","to":"burnHours","tot":"msg","dc":true}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":360,"wires":[["e6297bcf996a280a"]]},{"id":"e6297bcf996a280a","type":"debug","z":"bf569dbfc3bc07ed","name":"debug 344","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"burnHours","statusType":"msg","x":590,"y":400,"wires":[]},{"id":"6434ab7f47c2a49e","type":"inject","z":"bf569dbfc3bc07ed","name":"get total and delete","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"burn_sum","payloadType":"flow","x":130,"y":500,"wires":[["b46ab6a86f9d07ff"]]},{"id":"b46ab6a86f9d07ff","type":"change","z":"bf569dbfc3bc07ed","name":"","rules":[{"t":"delete","p":"burn_sum","pt":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":520,"wires":[["9faceef21aeeab45"]]},{"id":"9faceef21aeeab45","type":"debug","z":"bf569dbfc3bc07ed","name":"debug 345","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":590,"y":480,"wires":[]}]
A lot of nodes don't have documentation visible on flows.nodered.org. You have to navigate to their Github repo (see link on the same page), then you will see it appearing...
Here it is.
Hey All,
I'm just getting back to this. I made a few tweaks to what E1cid provided but I'm still not there. My goal is to render and record how many hours and minutes per day the fire is above 300 degrees.
Currently this flow puts out some numbers but they don't seem to be related to time. How can I set this up to show time burned?
        "id": "14df4444b40e6302",
        "type": "mqtt in",
        "z": "0e9443b6465b78e6",
        "topic": "/rmh/core",
        "qos": "2",
        "datatype": "auto-detect",
        "broker": "e8de652f3f0d5685",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 420,
        "y": 1220,
                "c014c8ab62e8708b",
                "b2a09457d1a9deec"
        "id": "f3b3efa30c4048b9",
        "type": "inject",
        "name": "get total and delete at midnight",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "59 23 * * *",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "burn_sum",
        "payloadType": "flow",
        "x": 490,
        "y": 1420,
                "8ec8fdbc98c2134e"
        "id": "8ec8fdbc98c2134e",
        "type": "change",
        "rules": [
                "t": "delete",
                "p": "burnSum",
                "pt": "flow"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 800,
        "y": 1420,
                "e18d5c75b433dab7"
        "id": "e18d5c75b433dab7",
        "type": "debug",
        "name": "debug 345",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 1010,
        "y": 1420,
        "id": "17e985bce66b4d6a",
        "type": "ui_text",
        "group": "a36b1802b62e1a87",
        "order": 1,
        "width": 0,
        "height": 0,
        "label": "Time Burned",
        "format": "{{msg.payload}}",
        "layout": "row-spread",
        "className": "",
        "style": false,
        "font": "",
        "fontSize": 16,
        "color": "#000000",
        "x": 1050,
        "y": 1360,
        "id": "af381cc47b5475d1",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "200",
        "payloadType": "num",
        "x": 410,
        "y": 1320,
                "5295c0401dc5c4c9"
        "id": "5295c0401dc5c4c9",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "burn",
                "pt": "msg",
                "to": "$$.payload > 300 ? \"on\" : \"off\"",
                "tot": "jsonata"
                "t": "set",
                "p": "timestamp",
                "pt": "msg",
                "to": "",
                "tot": "date"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 580,
        "y": 1300,
                "75c0963bb611b839"
        "id": "d48e8e325568f0b9",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "400",
        "x": 410,
        "y": 1280,
                "5295c0401dc5c4c9"
        "id": "75c0963bb611b839",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "property": "payload",
        "topi": "topic",
        "x": 730,
        "y": 1300,
                "50e4bf04242687ce"
        "id": "50e4bf04242687ce",
        "type": "join",
        "mode": "custom",
        "build": "object",
        "property": "timestamp",
        "propertyType": "msg",
        "key": "burn",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": true,
        "timeout": "",
        "count": "2",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "",
        "reduceFixup": "",
        "x": 850,
        "y": 1300,
                "cf08559d7ec6ef29"
        "id": "cf08559d7ec6ef29",
        "type": "switch",
        "property": "burn",
        "rules": [
                "t": "eq",
                "v": "on",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 550,
        "y": 1360,
                "9b1a936b212953d7"
        "id": "9b1a936b212953d7",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "burnMinutes",
                "pt": "msg",
                "to": "($$.timestamp.on - $$.timestamp.off)/60000",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 740,
        "y": 1360,
                "17e985bce66b4d6a",
                "3e01d0fc67467d6b"
        "id": "b2a09457d1a9deec",
        "type": "delay",
        "pauseType": "rate",
        "timeout": "5",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 610,
        "y": 1220,
                "5295c0401dc5c4c9"
        "id": "68ed3969abc24490",
        "type": "change",
        "name": "set flow.burnSum",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "burnSum",
                "tot": "flow"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 990,
        "y": 1240,
        "id": "3e01d0fc67467d6b",
        "type": "debug",
        "name": "debug 344",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "targetType": "full",
        "statusVal": "burnMinutes",
        "statusType": "msg",
        "x": 1030,
        "y": 1300,
        "id": "9ec4945dfa0b1b7a",
        "type": "comment",
        "name": "I think I need this but not sure how to incorporate",
        "info": "",
        "x": 1000,
        "y": 1200,
        "id": "e8de652f3f0d5685",
        "type": "mqtt-broker",
        "broker": "192.168.1.154",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "a36b1802b62e1a87",
        "type": "ui_group",
        "name": "Rocket Mass Heater",
        "tab": "f3a8a67ff0904e39",
        "order": 24,
        "disp": true,
        "width": "6",
        "collapse": true,
        "className": ""
        "id": "f3a8a67ff0904e39",
        "type": "ui_tab",
        "name": "Home",
        "icon": "home",
        "order": 1,
        "disabled": false,
        "hidden": false
You have set the switch node to pass on burn on, but should be burn off.
You have removed the JSONata which calculates the total burn time, so it will not sum the minutes.
I have added a third rule which calculates the total burn time in hours and minutes, I round it so it shows 0 till the total burn sum is longer than 30 seconds.
[{"id":"14df4444b40e6302","type":"mqtt in","z":"2493d0f1b4d72d1b","name":"","topic":"/rmh/core","qos":"2","datatype":"auto-detect","broker":"e8de652f3f0d5685","nl":false,"rap":true,"rh":0,"inputs":0,"x":280,"y":920,"wires":[["b2a09457d1a9deec"]]},{"id":"b2a09457d1a9deec","type":"delay","z":"2493d0f1b4d72d1b","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":470,"y":920,"wires":[["5295c0401dc5c4c9"]]},{"id":"5295c0401dc5c4c9","type":"change","z":"2493d0f1b4d72d1b","name":"","rules":[{"t":"set","p":"burn","pt":"msg","to":"$$.payload > 300 ? \"on\" : \"off\"","tot":"jsonata"},{"t":"set","p":"timestamp","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":1000,"wires":[["75c0963bb611b839"]]},{"id":"af381cc47b5475d1","type":"inject","z":"2493d0f1b4d72d1b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"200","payloadType":"num","x":270,"y":1020,"wires":[["5295c0401dc5c4c9"]]},{"id":"d48e8e325568f0b9","type":"inject","z":"2493d0f1b4d72d1b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"400","payloadType":"num","x":270,"y":980,"wires":[["5295c0401dc5c4c9"]]},{"id":"75c0963bb611b839","type":"rbe","z":"2493d0f1b4d72d1b","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":590,"y":1000,"wires":[["50e4bf04242687ce"]]},{"id":"50e4bf04242687ce","type":"join","z":"2493d0f1b4d72d1b","name":"","mode":"custom","build":"object","property":"timestamp","propertyType":"msg","key":"burn","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":710,"y":1000,"wires":[["cf08559d7ec6ef29"]]},{"id":"cf08559d7ec6ef29","type":"switch","z":"2493d0f1b4d72d1b","name":"","property":"burn","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":410,"y":1060,"wires":[["5d62c80531f8eadf"]]},{"id":"5d62c80531f8eadf","type":"change","z":"2493d0f1b4d72d1b","name":"","rules":[{"t":"set","p":"burnMinutes","pt":"msg","to":"$sum([$flowContext(\"burnSum\")]) + ($$.timestamp.off - $$.timestamp.on)/60000","tot":"jsonata"},{"t":"set","p":"burnSum","pt":"flow","to":"burnMinutes","tot":"msg","dc":true},{"t":"set","p":"payload","pt":"msg","to":"$pad( $string( $floor($$.burnMinutes/60) ),-2, \"0\") & \":\" & $pad( $string( $round($$.burnMinutes % 60) ),-2 , \"0\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":1060,"wires":[["17e985bce66b4d6a","3e01d0fc67467d6b"]]},{"id":"17e985bce66b4d6a","type":"ui_text","z":"2493d0f1b4d72d1b","group":"a36b1802b62e1a87","order":1,"width":0,"height":0,"name":"","label":"Time Burned","format":"{{msg.payload}}","layout":"row-spread","className":"","style":false,"font":"","fontSize":16,"color":"#000000","x":910,"y":1060,"wires":[]},{"id":"3e01d0fc67467d6b","type":"debug","z":"2493d0f1b4d72d1b","name":"debug 344","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"burnMinutes","statusType":"msg","x":910,"y":1000,"wires":[]},{"id":"f3b3efa30c4048b9","type":"inject","z":"2493d0f1b4d72d1b","name":"get total and delete at midnight","props":[{"p":"payload"}],"repeat":"","crontab":"59 23 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"burnSum","payloadType":"flow","x":350,"y":1120,"wires":[["8ec8fdbc98c2134e"]]},{"id":"8ec8fdbc98c2134e","type":"change","z":"2493d0f1b4d72d1b","name":"","rules":[{"t":"delete","p":"burnSum","pt":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":1120,"wires":[["e18d5c75b433dab7"]]},{"id":"e18d5c75b433dab7","type":"debug","z":"2493d0f1b4d72d1b","name":"debug 345","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":870,"y":1120,"wires":[]},{"id":"e8de652f3f0d5685","type":"mqtt-broker","name":"","broker":"192.168.1.154","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"a36b1802b62e1a87","type":"ui_group","name":"Rocket Mass Heater","tab":"f3a8a67ff0904e39","order":24,"disp":true,"width":"6","collapse":true,"className":""},{"id":"f3a8a67ff0904e39","type":"ui_tab","name":"Home","icon":"home","order":1,"disabled":false,"hidden":false}]
Thanks, when I try this I get the following error.
"Invalid JSONata expression: The values "nan" and 300 either side of operator ">" must be of the same data type"
Note that the numbers coming in are floats with one decimal place i.e. 300.1 not sure if that matters.
I stripped the float and it's no longer getting an error
However the dashboard just renders 00:00
How long did you give it when testing.
You received the error as incoming mqtt value is a string not a float.
This should handle strings or floats or integers incoming e.g "300.1"
[{"id":"14df4444b40e6302","type":"mqtt in","z":"b779de97.b1b46","name":"","topic":"/rmh/core","qos":"2","datatype":"auto-detect","broker":"e8de652f3f0d5685","nl":false,"rap":true,"rh":0,"inputs":0,"x":180,"y":4780,"wires":[["b2a09457d1a9deec"]]},{"id":"b2a09457d1a9deec","type":"delay","z":"b779de97.b1b46","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":370,"y":4780,"wires":[["5295c0401dc5c4c9"]]},{"id":"5295c0401dc5c4c9","type":"change","z":"b779de97.b1b46","name":"","rules":[{"t":"set","p":"burn","pt":"msg","to":"$number($$.payload) > 300 ? \"on\" : \"off\"","tot":"jsonata"},{"t":"set","p":"timestamp","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":4860,"wires":[["75c0963bb611b839"]]},{"id":"af381cc47b5475d1","type":"inject","z":"b779de97.b1b46","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"200","payloadType":"num","x":170,"y":4880,"wires":[["5295c0401dc5c4c9"]]},{"id":"d48e8e325568f0b9","type":"inject","z":"b779de97.b1b46","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"400","payloadType":"num","x":170,"y":4840,"wires":[["5295c0401dc5c4c9"]]},{"id":"75c0963bb611b839","type":"rbe","z":"b779de97.b1b46","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":490,"y":4860,"wires":[["50e4bf04242687ce"]]},{"id":"50e4bf04242687ce","type":"join","z":"b779de97.b1b46","name":"","mode":"custom","build":"object","property":"timestamp","propertyType":"msg","key":"burn","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":610,"y":4860,"wires":[["cf08559d7ec6ef29"]]},{"id":"cf08559d7ec6ef29","type":"switch","z":"b779de97.b1b46","name":"","property":"burn","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":310,"y":4920,"wires":[["5d62c80531f8eadf"]]},{"id":"5d62c80531f8eadf","type":"change","z":"b779de97.b1b46","name":"","rules":[{"t":"set","p":"burnMinutes","pt":"msg","to":"$sum([$flowContext(\"burnSum\")]) + ($$.timestamp.off - $$.timestamp.on)/60000","tot":"jsonata"},{"t":"set","p":"burnSum","pt":"flow","to":"burnMinutes","tot":"msg","dc":true},{"t":"set","p":"payload","pt":"msg","to":"$pad( $string( $floor($$.burnMinutes/60) ),-2, \"0\") & \":\" & $pad( $string( $round($$.burnMinutes % 60) ),-2 , \"0\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":4920,"wires":[["17e985bce66b4d6a","3e01d0fc67467d6b"]]},{"id":"17e985bce66b4d6a","type":"ui_text","z":"b779de97.b1b46","group":"a36b1802b62e1a87","order":1,"width":0,"height":0,"name":"","label":"Time Burned","format":"{{msg.payload}}","layout":"row-spread","className":"","style":false,"font":"","fontSize":16,"color":"#000000","x":810,"y":4920,"wires":[]},{"id":"3e01d0fc67467d6b","type":"debug","z":"b779de97.b1b46","name":"debug 344","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"burnMinutes","statusType":"msg","x":810,"y":4860,"wires":[]},{"id":"f3b3efa30c4048b9","type":"inject","z":"b779de97.b1b46","name":"get total and delete at midnight","props":[{"p":"payload"}],"repeat":"","crontab":"59 23 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"burnSum","payloadType":"flow","x":250,"y":4980,"wires":[["8ec8fdbc98c2134e"]]},{"id":"8ec8fdbc98c2134e","type":"change","z":"b779de97.b1b46","name":"","rules":[{"t":"delete","p":"burnSum","pt":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":4980,"wires":[["e18d5c75b433dab7"]]},{"id":"e18d5c75b433dab7","type":"debug","z":"b779de97.b1b46","name":"debug 345","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":770,"y":4980,"wires":[]},{"id":"e8de652f3f0d5685","type":"mqtt-broker","name":"","broker":"192.168.1.154","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"a36b1802b62e1a87","type":"ui_group","name":"Rocket Mass Heater","tab":"f3a8a67ff0904e39","order":24,"disp":true,"width":"6","collapse":true,"className":""},{"id":"f3a8a67ff0904e39","type":"ui_tab","name":"Home","icon":"home","order":1,"disabled":false,"hidden":false}]
A few minutes. The time doesn't change and stays at 00:00.
Are you saying the example i posted above does not change, seems strange as clearly in image i have posted it does. You must be using an edited version. If you are then more info will be required to see what is occurring.
hmm, when I checked it this morning it shows a static, unchanging number 18033:14
Now I'm getting this error
"Invalid JSONata expression: Unable to cast value to a number: "nan""
Here is the flow
        "id": "4adeb8e7d2204452",
        "type": "mqtt in",
        "z": "3bec4593b80f93c3",
        "qos": "2",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 420,
        "y": 280,
                "fda91984c826b9e0"
        "id": "fda91984c826b9e0",
        "type": "delay",
        "timeout": "5",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 610,
        "y": 280,
                "f3b373b878e65f40"
        "id": "f3b373b878e65f40",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "burn",
                "pt": "msg",
                "to": "$number($$.payload) > 300 ? \"on\" : \"off\"",
                "tot": "jsonata"
                "t": "set",
                "p": "timestamp",
                "pt": "msg",
                "to": "",
                "tot": "date"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 580,
        "y": 360,
                "e1d404b88bfc0aa5"
        "id": "100934e985d8fd7f",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "200",
        "x": 370,
        "y": 380,
                "f3b373b878e65f40"
        "id": "746a5bb32cbe140e",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "400",
        "x": 370,
        "y": 340,
                "f3b373b878e65f40"
        "id": "e1d404b88bfc0aa5",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 730,
        "y": 360,
                "3f0ba7d234fc4319"
        "id": "3f0ba7d234fc4319",
        "type": "join",
        "mode": "custom",
        "build": "object",
        "key": "burn",
        "joiner": "\\n",
        "accumulate": true,
        "timeout": "",
        "count": "2",
        "reduceExp": "",
        "reduceInit": "",
        "reduceFixup": "",
        "x": 850,
        "y": 360,
                "f02ec50af2618cce",
                "b0040172bb18fac9"
        "id": "f02ec50af2618cce",
        "type": "switch",
        "property": "burn",
        "rules": [
                "t": "eq",
                "v": "off",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 550,
        "y": 420,
                "cfc4f78d370412d3"
        "id": "cfc4f78d370412d3",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "burnMinutes",
                "pt": "msg",
                "to": "$sum([$flowContext(\"burnSum\")]) + ($$.timestamp.off - $$.timestamp.on)/60000",
                "tot": "jsonata"
                "t": "set",
                "p": "burnSum",
                "pt": "flow",
                "to": "burnMinutes",
                "tot": "msg",
                "dc": true
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "$pad( $string( $floor($$.burnMinutes/60) ),-2, \"0\") & \":\" & $pad( $string( $round($$.burnMinutes % 60) ),-2 , \"0\")",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 760,
        "y": 420,
                "c47a78ec139f34f4"
        "id": "c47a78ec139f34f4",
        "type": "ui_text",
        "order": 1,
        "width": 0,
        "height": 0,
        "className": "",
        "style": false,
        "font": "",
        "fontSize": 16,
        "color": "#000000",
        "x": 1050,
        "y": 420,
        "id": "b0040172bb18fac9",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "true",
        "x": 1010,
        "y": 220,
        "id": "eaab94a3a0a884c9",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "burnSum",
        "x": 490,
        "y": 480,
                "c68dcc1a2f7489df"
        "id": "c68dcc1a2f7489df",
        "type": "change",
        "rules": [
                "t": "delete",
                "p": "burnSum",
                "pt": "flow"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 800,
        "y": 480,
                "9094b8b9eb574e7e"
        "id": "9094b8b9eb574e7e",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "x": 1010,
        "y": 480,
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "type": "ui_group",
        "order": 24,
        "disp": true,
        "width": "6",
        "collapse": true,
        "className": ""
        "type": "ui_tab",
        "name": "Home",
        "icon": "home",
        "order": 1,
        "disabled": false,
        "hidden": false
Not enough info
Which node is throwing error? I suspect the first change node, please confirm.
What are the inputs of the mqtt node, monitor them and then provide all the different payloads, as I suspect you are not just getting the temp payloads.
Yes, it's the first change node.
this is what's coming out of the mqtt node
Screenshot 2023-10-20 101945
How long did you monitor it, that payload would not throw an error.
Also show us your context store value.
THe debug in this flow will log any non numbers to debug sidebar
[{"id":"7971f06b37810726","type":"inject","z":"2493d0f1b4d72d1b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"400.1","payloadType":"num","x":310,"y":1440,"wires":[["52f5d3e4b606524d"]]},{"id":"52f5d3e4b606524d","type":"switch","z":"2493d0f1b4d72d1b","name":"","property":"payload","propertyType":"msg","rules":[{"t":"istype","v":"number","vt":"number"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":430,"y":1420,"wires":[["ac29fabac2f00219"],["94c5192c3e0f8e4c"]]},{"id":"ce4c1df7eb979ae7","type":"inject","z":"2493d0f1b4d72d1b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"200","payloadType":"num","x":310,"y":1480,"wires":[["52f5d3e4b606524d"]]},{"id":"ac29fabac2f00219","type":"change","z":"2493d0f1b4d72d1b","name":"","rules":[{"t":"set","p":"burn","pt":"msg","to":"$number($$.payload) > 300 ? \"on\" : \"off\"","tot":"jsonata"},{"t":"set","p":"timestamp","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":1460,"wires":[["1d355db417eba54e"]]},{"id":"94c5192c3e0f8e4c","type":"debug","z":"2493d0f1b4d72d1b","name":"debug 346","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":510,"y":1320,"wires":[]},{"id":"1d355db417eba54e","type":"rbe","z":"2493d0f1b4d72d1b","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":670,"y":1460,"wires":[["8616bd24893b4a03"]]},{"id":"8616bd24893b4a03","type":"join","z":"2493d0f1b4d72d1b","name":"","mode":"custom","build":"object","property":"timestamp","propertyType":"msg","key":"burn","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":790,"y":1460,"wires":[["c93ffeeca4007a28"]]},{"id":"c93ffeeca4007a28","type":"switch","z":"2493d0f1b4d72d1b","name":"","property":"burn","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":490,"y":1520,"wires":[["333201a2b10e3802"]]},{"id":"333201a2b10e3802","type":"change","z":"2493d0f1b4d72d1b","name":"","rules":[{"t":"set","p":"burnMinutes","pt":"msg","to":"$sum([$flowContext(\"burnSum\")]) + ($$.timestamp.off - $$.timestamp.on)/60000","tot":"jsonata"},{"t":"set","p":"burnSum","pt":"flow","to":"burnMinutes","tot":"msg","dc":true},{"t":"set","p":"payload","pt":"msg","to":"$pad( $string( $floor($$.burnMinutes/60) ),-2, \"0\") & \":\" & $pad( $string( $round($$.burnMinutes % 60) ),-2 , \"0\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":1520,"wires":[["fbfaebdbbe412228","84e61e8b69716b01"]]},{"id":"fbfaebdbbe412228","type":"ui_text","z":"2493d0f1b4d72d1b","group":"a36b1802b62e1a87","order":1,"width":0,"height":0,"name":"","label":"Time Burned","format":"{{msg.payload}}","layout":"row-spread","className":"","style":false,"font":"","fontSize":16,"color":"#000000","x":990,"y":1520,"wires":[]},{"id":"84e61e8b69716b01","type":"debug","z":"2493d0f1b4d72d1b","name":"debug 344","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"burnMinutes","statusType":"msg","x":790,"y":1340,"wires":[]},{"id":"a36b1802b62e1a87","type":"ui_group","name":"Rocket Mass Heater","tab":"f3a8a67ff0904e39","order":24,"disp":true,"width":"6","collapse":true,"className":""},{"id":"f3a8a67ff0904e39","type":"ui_tab","name":"Home","icon":"home","order":1,"disabled":false,"hidden":false}]
feed your mqtt node into the switch node
Looks to me like your mqtt node is returning payload values of NaN, the switch node should filter them and sort the issue. You may want to look at why your sensor is returning these value though.
Yes, I am occasionally seeing NaN readings, they come at random times.
I'm getting a reading every second or so. Monitoring is ongoing.
The last code you posted does not render anything to the dashboard, blank.
Nor will it, till you receive 1 reading over 300 and 1 below.
You provide no information as to what readings the flow has received, hard to help with limited info.
I found the Hourglass node and got it working.
Thanks for wading through the weeds with me on this E1cid! The support I get on this forum is unparalleled! You and the other regulars do an excellent job.
Much appreciated!
        "id": "10ef739ae222708f",
        "type": "switch",
        "name": "is it a number?",
        "rules": [
                "t": "istype",
                "v": "number",
                "vt": "number"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 280,
        "y": 360,
                "fe5a8184e294562d"
        "id": "4803cbe23bbdc274",
        "type": "ui_text",
        "order": 1,
        "width": 0,
        "height": 0,
        "format": "{{msg.elapsed.time.minutes}}:{{msg.elapsed.time.seconds}}",
        "className": "",
        "style": false,
        "font": "",
        "fontSize": 16,
        "color": "#000000",
        "x": 990,
        "y": 340,
        "id": "3aec4d681ab3c3e0",
        "type": "mqtt in",
        "qos": "2",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 120,
        "y": 360,
                "10ef739ae222708f"
        "id": "92109e0a.88d96",
        "type": "hourglass",
        "persistId": "",
        "humanizeLocale": "",
        "x": 840,
        "y": 360,
                "4803cbe23bbdc274",
                "f4f9d1c1226ca057"
        "id": "5a0a72af.5c5fc4",
        "type": "change",
        "name": "{command:'reset'}",
        "rules": [
                "t": "set",
                "p": "command",
                "pt": "msg",
                "to": "reset",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 650,
        "y": 420,
                "92109e0a.88d96"
        "id": "cfff0e2d.ada0e8",
        "type": "change",
        "name": "{command:'start'}",
        "rules": [
                "t": "set",
                "p": "command",
                "pt": "msg",
                "to": "start",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 650,
        "y": 340,
                "92109e0a.88d96"
        "id": "a0a2d80e.88f7d",
        "type": "change",
        "name": "{command:'stop'}",
        "rules": [
                "t": "set",
                "p": "command",
                "pt": "msg",
                "to": "stop",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 650,
        "y": 380,
                "92109e0a.88d96"
        "id": "894f06df.59219",
        "type": "inject",
        "name": "reset at midnight",
        "props": [
                "p": "payload"
        "repeat": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "str",
        "x": 430,
        "y": 420,
                "5a0a72af.5c5fc4"
        "id": "6384eb1d.90bca4",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "1",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 470,
        "y": 300,
                "5bb3a7b5.cb8b9"
        "id": "5bb3a7b5.cb8b9",
        "type": "change",
        "name": "{command:'status'}",
        "rules": [
                "t": "set",
                "p": "command",
                "pt": "msg",
                "to": "status",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 650,
        "y": 300,
                "92109e0a.88d96"
        "id": "fe5a8184e294562d",
        "type": "switch",
        "name": "Over 300?",
        "rules": [
                "t": "gte",
                "v": "335",
                "vt": "num"
                "t": "lt",
                "v": "335",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 450,
        "y": 360,
                "cfff0e2d.ada0e8"
                "a0a2d80e.88f7d"
        "id": "f4f9d1c1226ca057",
        "type": "debug",
        "name": "debug 395",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 990,
        "y": 380,
        "type": "ui_group",
        "order": 24,
        "disp": true,
        "width": "6",
        "collapse": true,
        "className": ""
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "type": "ui_tab",
        "name": "Home",
        "icon": "home",
        "order": 1,
        "disabled": false,
        "hidden": false
