Hi zenofmud,
Thanks for your reply!
I've already read a lot about the getDate function.
I did follow your link, but still I don't find the solution.
I tried a lot. I don't know where to look anymore.
I got the time from a timer function.
Do you know if the output of the timer function can be used for calculations?
I will share the flow below:
[{"id":"fd7c4176.ab8a7","type":"comment","z":"da622957.7a8bf8","name":" Availability = Downtime / Total Time ","info":"","x":220,"y":60,"wires":[]},{"id":"7b812286.ed5d4c","type":"inject","z":"da622957.7a8bf8","name":"on","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"on","payload":"","payloadType":"date","x":130,"y":420,"wires":[["d44f5e55.24191"]]},{"id":"ff30dd5c.c16b18","type":"inject","z":"da622957.7a8bf8","name":"off","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"off","payload":"","payloadType":"date","x":130,"y":460,"wires":[["d44f5e55.24191"]]},{"id":"6c168a15.61460c","type":"inject","z":"da622957.7a8bf8","name":"reset","props":[{"p":"payload","v":"","vt":"date"},{"p":"topic","v":"reset","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"reset","payload":"","payloadType":"date","x":130,"y":500,"wires":[["d44f5e55.24191"]]},{"id":"957a824.8d04d","type":"debug","z":"da622957.7a8bf8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":870,"y":500,"wires":[]},{"id":"d44f5e55.24191","type":"dsm","z":"da622957.7a8bf8","name":"operating time","sm_config":"{\n \"currentState\": \"stopped1\",\n \"states\": {\n \"stopped1\": {\n \"on\": \"started1\"\n },\n \"started1\": {\n \"inc\": \"counting1\",\n \"off\": \"stopped1\"\n },\n \"counting1\": {\n \"inc\": \"counting1\",\n \"off\": \"stopped1\"\n }\n },\n \"data\": {\n \"prev_time\": null,\n \"time\": 0,\n \"seconds\": 0,\n \"interval\": 1,\n \"interval_output\": true,\n \"hms_format\": true\n },\n \"methods\": {\n \"init\": [\n \"sm.calc_time = function() {\",\n \" var now = Date.now();\",\n \" sm.data.time += now - sm.data.prev_time;\",\n \" sm.data.prev_time = now;\",\n \" sm.data.seconds = Math.round(sm.data.time / 1000);\",\n \"};\",\n \"sm.sec2hhmmss = function(sec) {\",\n \"var t = {};\",\n \"t.h = pad(Math.floor(sec / 3600));\",\n \"sec %= 3600;\",\n \"t.m = pad(Math.floor(sec / 60));\",\n \"t.s = pad(sec % 60);\",\n \"return t.h+':'+t.m+':'+t.s;\",\n \"};\"\n ],\n \"on\": [\n \"if (sm.currentState === 'started1') {\",\n \" sm.data.prev_time = Date.now();\",\n \" resume('inc', msg);\",\n \"}\",\n \"output = false;\"\n ],\n \"inc\": [\n \"timeout.interval = setTimeout(function() {\",\n \" sm.calc_time();\",\n \" msg.data = sm.data;\",\n \" if (sm.data.interval_output) {\",\n \" msg.payload = sm.data.hms_format ? sm.sec2hhmmss(sm.data.seconds): sm.data.seconds;\",\n \" node.send(msg);\",\n \" }\",\n \" resume('inc', msg);\",\n \"}, sm.data.interval*1000);\",\n \"output = false;\"\n ],\n \"off\": [\n \"clearTimeout(timeout.interval);\",\n \"sm.calc_time();\",\n \"msg.payload = sm.data.hms_format ? sm.sec2hhmmss(sm.data.seconds): sm.data.seconds;\"\n ],\n \"reset\": [\n \"sm.data.time = 0;\",\n \"sm.data.seconds = 0;\"\n ],\n \"status\": {\n \"fill\": {\n \"get\": \"sm.currentState === 'counting1' ? 'green' : 'grey';\"\n },\n \"shape\": \"dot\",\n \"text\": {\n \"get\": \"'time ' + (sm.data.hms_format ? sm.sec2hhmmss(sm.data.seconds): sm.data.seconds);\"\n }\n }\n }\n}\n","x":410,"y":460,"wires":[["d8845bab.6c9818","7a0a2523.84d74c"]]},{"id":"7afc18a9.0367a","type":"comment","z":"da622957.7a8bf8","name":"Total Time","info":"","x":160,"y":300,"wires":[]},{"id":"bb327f27.b0865","type":"link in","z":"da622957.7a8bf8","name":"","links":["752be2a7.4a0f3c","d5dd8f7e.bc482"],"x":275,"y":360,"wires":[["d44f5e55.24191"]]},{"id":"225cc97e.a3dcf6","type":"link in","z":"da622957.7a8bf8","name":"","links":["16e15d3a.8a3bcb","3129dd13.ffce6a"],"x":255,"y":440,"wires":[["d44f5e55.24191"]]},{"id":"fb79f2f6.370cb8","type":"link in","z":"da622957.7a8bf8","name":"","links":["ac2d0db8.12613","73808281.ba64fc"],"x":265,"y":400,"wires":[["d44f5e55.24191"]]},{"id":"d8845bab.6c9818","type":"influxdb out","z":"da622957.7a8bf8","influxdb":"52a06381.0494c4","name":"Database: raspioee (TotalTime)","measurement":"Total_Time","precision":"s","retentionPolicy":"","x":650,"y":380,"wires":[]},{"id":"50688912.3695a8","type":"comment","z":"da622957.7a8bf8","name":"Downtime","info":"","x":170,"y":720,"wires":[]},{"id":"1fec94bf.748fc3","type":"interval-length","z":"da622957.7a8bf8","format":"human","bytopic":true,"minimum":"","maximum":"","window":"","timeout":false,"msgTimeout":"10","minimumunit":"msecs","maximumunit":"msecs","windowunit":"msecs","msgTimeoutUnit":"secs","reset":true,"startup":true,"msgField":"interval","timestampField":"timestamp","repeatTimeout":false,"name":"","x":160,"y":880,"wires":[["8ee8d34a.cdcea","91003569.b226c8","2a0abc2c.b9258c"],["fc462763.3da72","5b0c8405.ef408c"]]},{"id":"57a73e2f.bc883","type":"change","z":"da622957.7a8bf8","name":"topic = \"sensorWELW\"","rules":[{"t":"set","p":"topic","pt":"msg","to":"sensorWELW","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":180,"y":840,"wires":[["1fec94bf.748fc3"]]},{"id":"fc462763.3da72","type":"debug","z":"da622957.7a8bf8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":590,"y":880,"wires":[]},{"id":"8ee8d34a.cdcea","type":"debug","z":"da622957.7a8bf8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":590,"y":840,"wires":[]},{"id":"c32fd39c.b56148","type":"influxdb out","z":"da622957.7a8bf8","influxdb":"52a06381.0494c4","name":"Database: raspioee (AlarmTest)","measurement":"AlarmTest","precision":"s","retentionPolicy":"","x":650,"y":760,"wires":[]},{"id":"91003569.b226c8","type":"function","z":"da622957.7a8bf8","name":"","func":"var interval =msg.interval\n\n \nif (interval>10.00) ;\n{\n msg.payload=\n {\n numValue: interval,\n\n }}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":420,"y":760,"wires":[["c32fd39c.b56148"]]},{"id":"f1936937.055bb8","type":"inject","z":"da622957.7a8bf8","name":"SensorWELW","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":800,"wires":[["57a73e2f.bc883"]]},{"id":"ee424fba.c01d7","type":"inject","z":"da622957.7a8bf8","name":"on","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"on","payload":"","payloadType":"date","x":210,"y":1240,"wires":[["51cebe96.f19048"]]},{"id":"73c2677b.ca95e","type":"inject","z":"da622957.7a8bf8","name":"off","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"off","payload":"","payloadType":"date","x":210,"y":1280,"wires":[["51cebe96.f19048"]]},{"id":"234e49b4.8d06c6","type":"inject","z":"da622957.7a8bf8","name":"reset","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"2","topic":"reset","payload":"","payloadType":"date","x":210,"y":1320,"wires":[["51cebe96.f19048"]]},{"id":"fd07da2d.a08d4","type":"debug","z":"da622957.7a8bf8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":910,"y":1280,"wires":[]},{"id":"51cebe96.f19048","type":"dsm","z":"da622957.7a8bf8","name":"Total Downtime Counter","sm_config":"{\n \"currentState\": \"stopped\",\n \"states\": {\n \"stopped\": {\n \"on\": \"started\"\n },\n \"started\": {\n \"inc\": \"counting\",\n \"off\": \"stopped\"\n },\n \"counting\": {\n \"inc\": \"counting\",\n \"off\": \"stopped\"\n }\n },\n \"data\": {\n \"prev_time\": null,\n \"time\": 0,\n \"seconds\": 0,\n \"interval\": 1,\n \"interval_output\": true,\n \"hms_format\": true\n },\n \"methods\": {\n \"init\": [\n \"sm.calc_time = function() {\",\n \" var now = Date.now();\",\n \" sm.data.time += now - sm.data.prev_time;\",\n \" sm.data.prev_time = now;\",\n \" sm.data.seconds = Math.round(sm.data.time / 1000);\",\n \"};\",\n \"sm.sec2hhmmss = function(sec) {\",\n \"var t = {};\",\n \"t.h = pad(Math.floor(sec / 3600));\",\n \"sec %= 3600;\",\n \"t.m = pad(Math.floor(sec / 60));\",\n \"t.s = pad(sec % 60);\",\n \"return t.h+':'+t.m+':'+t.s;\",\n \"};\"\n ],\n \"on\": [\n \"if (sm.currentState === 'started') {\",\n \" sm.data.prev_time = Date.now();\",\n \" resume('inc', msg);\",\n \"}\",\n \"output = false;\"\n ],\n \"inc\": [\n \"timeout.interval = setTimeout(function() {\",\n \" sm.calc_time();\",\n \" msg.data = sm.data;\",\n \" if (sm.data.interval_output) {\",\n \" msg.payload = sm.data.hms_format ? sm.sec2hhmmss(sm.data.seconds): sm.data.seconds;\",\n \" node.send(msg);\",\n \" }\",\n \" resume('inc', msg);\",\n \"}, sm.data.interval*1000);\",\n \"output = false;\"\n ],\n \"off\": [\n \"clearTimeout(timeout.interval);\",\n \"sm.calc_time();\",\n \"msg.payload = sm.data.hms_format ? sm.sec2hhmmss(sm.data.seconds): sm.data.seconds;\"\n ],\n \"reset\": [\n \"sm.data.time = 0;\",\n \"sm.data.seconds = 0;\"\n ],\n \"status\": {\n \"fill\": {\n \"get\": \"sm.currentState === 'counting' ? 'green' : 'grey';\"\n },\n \"shape\": \"dot\",\n \"text\": {\n \"get\": \"'time ' + (sm.data.hms_format ? sm.sec2hhmmss(sm.data.seconds): sm.data.seconds);\"\n }\n }\n }\n}\n","x":500,"y":1280,"wires":[["59f9dddb.7b8c6c","309c1637.cf2722"]]},{"id":"5b0c8405.ef408c","type":"change","z":"da622957.7a8bf8","name":"Set \"on\"","rules":[{"t":"set","p":"topic","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":180,"y":920,"wires":[["665501a.711ea","6de35ad1.e4817c","f3ce9d78.89bc9"]]},{"id":"59f9dddb.7b8c6c","type":"influxdb out","z":"da622957.7a8bf8","influxdb":"52a06381.0494c4","name":"Database: raspioee (Downtime_Counter)","measurement":"Total_Downtime_Counter","precision":"s","retentionPolicy":"","x":680,"y":1220,"wires":[]},{"id":"96f7d727.4d0b18","type":"debug","z":"da622957.7a8bf8","name":"","active":false,"console":"false","complete":"false","x":690,"y":980,"wires":[]},{"id":"2a0abc2c.b9258c","type":"trigger","z":"da622957.7a8bf8","name":"","op1":"","op2":"0","op1type":"pay","op2type":"str","duration":"0","extend":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":500,"y":920,"wires":[["96f7d727.4d0b18","8c07b35c.856718"]]},{"id":"665501a.711ea","type":"change","z":"da622957.7a8bf8","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":980,"wires":[["2a0abc2c.b9258c"]]},{"id":"7c9866ff.d51318","type":"link in","z":"da622957.7a8bf8","name":"Downtime_Off","links":["8a4b50a5.b90008"],"x":335,"y":1220,"wires":[["51cebe96.f19048"]]},{"id":"8a4b50a5.b90008","type":"link out","z":"da622957.7a8bf8","name":"Downtime_Off","links":["220b40cc.82d848","7c9866ff.d51318","9e736227.96beb"],"x":795,"y":940,"wires":[]},{"id":"8c07b35c.856718","type":"change","z":"da622957.7a8bf8","name":"Set \"off\"","rules":[{"t":"set","p":"topic","pt":"msg","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":940,"wires":[["8a4b50a5.b90008"]]},{"id":"6de35ad1.e4817c","type":"link out","z":"da622957.7a8bf8","name":"Downtime_On","links":["b578119d.c7a978","87b115c3.d1f6b8","a5ca323b.38f5a8","e8d4357a.d92ab8"],"x":295,"y":1000,"wires":[]},{"id":"b578119d.c7a978","type":"link in","z":"da622957.7a8bf8","name":"","links":["6de35ad1.e4817c"],"x":335,"y":1180,"wires":[["51cebe96.f19048"]]},{"id":"dec927f2.f487a8","type":"comment","z":"da622957.7a8bf8","name":"Total Downtime Counter","info":"","x":210,"y":1120,"wires":[]},{"id":"ebb77ba4.5a5778","type":"inject","z":"da622957.7a8bf8","name":"on","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"on","payload":"","payloadType":"date","x":210,"y":1540,"wires":[["96f5c632.cbdc28"]]},{"id":"25b8d7b7.2893e8","type":"inject","z":"da622957.7a8bf8","name":"off","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"0.6","topic":"off","payload":"","payloadType":"date","x":210,"y":1580,"wires":[["96f5c632.cbdc28"]]},{"id":"c03b6ab0.eb4c08","type":"inject","z":"da622957.7a8bf8","name":"reset","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"1","topic":"reset","payload":"","payloadType":"date","x":210,"y":1620,"wires":[["96f5c632.cbdc28"]]},{"id":"f5b21cb6.4b917","type":"debug","z":"da622957.7a8bf8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":710,"y":1580,"wires":[]},{"id":"9e736227.96beb","type":"link in","z":"da622957.7a8bf8","name":"","links":["8a4b50a5.b90008"],"x":335,"y":1520,"wires":[["96f5c632.cbdc28"]]},{"id":"19b5c9f2.5c111e","type":"influxdb out","z":"da622957.7a8bf8","influxdb":"52a06381.0494c4","name":"Database: raspioee (Downtime_Last_Stop)","measurement":"Downtime_Last_Stop","precision":"s","retentionPolicy":"","x":690,"y":1520,"wires":[]},{"id":"87b115c3.d1f6b8","type":"link in","z":"da622957.7a8bf8","name":"","links":["6de35ad1.e4817c"],"x":335,"y":1480,"wires":[["96f5c632.cbdc28"]]},{"id":"891b9861.5b7a7","type":"comment","z":"da622957.7a8bf8","name":"Downtime since last Stop","info":"","x":210,"y":1440,"wires":[]},{"id":"3d77ad67.8fb9c2","type":"link in","z":"da622957.7a8bf8","name":"","links":["e2b78d97.5eab","d75aea2f.98a96"],"x":315,"y":920,"wires":[["2a0abc2c.b9258c"]]},{"id":"85706acb.20b2b8","type":"change","z":"da622957.7a8bf8","name":"Reset","rules":[{"t":"set","p":"topic","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":1680,"wires":[["96f5c632.cbdc28"]]},{"id":"e8d4357a.d92ab8","type":"link in","z":"da622957.7a8bf8","name":"","links":["6de35ad1.e4817c"],"x":215,"y":1680,"wires":[["85706acb.20b2b8"]]},{"id":"159b756d.ab0d1b","type":"link in","z":"da622957.7a8bf8","name":"","links":["16e15d3a.8a3bcb","e2b78d97.5eab","3129dd13.ffce6a","d75aea2f.98a96"],"x":305,"y":1340,"wires":[["51cebe96.f19048"]]},{"id":"f3ce9d78.89bc9","type":"debug","z":"da622957.7a8bf8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":460,"y":1060,"wires":[]},{"id":"96f5c632.cbdc28","type":"dsm","z":"da622957.7a8bf8","name":"Downtime since last Stop","sm_config":"{\n \"currentState\": \"stopped\",\n \"states\": {\n \"stopped\": {\n \"on\": \"started\"\n },\n \"started\": {\n \"inc\": \"counting\",\n \"off\": \"stopped\"\n },\n \"counting\": {\n \"inc\": \"counting\",\n \"off\": \"stopped\"\n }\n },\n \"data\": {\n \"prev_time\": null,\n \"time\": 0,\n \"seconds\": 0,\n \"interval\": 1,\n \"interval_output\": true,\n \"hms_format\": true\n },\n \"methods\": {\n \"init\": [\n \"sm.calc_time = function() {\",\n \" var now = Date.now();\",\n \" sm.data.time += now - sm.data.prev_time;\",\n \" sm.data.prev_time = now;\",\n \" sm.data.seconds = Math.round(sm.data.time / 1000);\",\n \"};\",\n \"sm.sec2hhmmss = function(sec) {\",\n \"var t = {};\",\n \"t.h = pad(Math.floor(sec / 3600));\",\n \"sec %= 3600;\",\n \"t.m = pad(Math.floor(sec / 60));\",\n \"t.s = pad(sec % 60);\",\n \"return t.h+':'+t.m+':'+t.s;\",\n \"};\"\n ],\n \"on\": [\n \"if (sm.currentState === 'started') {\",\n \" sm.data.prev_time = Date.now();\",\n \" resume('inc', msg);\",\n \"}\",\n \"output = false;\"\n ],\n \"inc\": [\n \"timeout.interval = setTimeout(function() {\",\n \" sm.calc_time();\",\n \" msg.data = sm.data;\",\n \" if (sm.data.interval_output) {\",\n \" msg.payload = sm.data.hms_format ? sm.sec2hhmmss(sm.data.seconds): sm.data.seconds;\",\n \" node.send(msg);\",\n \" }\",\n \" resume('inc', msg);\",\n \"}, sm.data.interval*1000);\",\n \"output = false;\"\n ],\n \"off\": [\n \"clearTimeout(timeout.interval);\",\n \"sm.calc_time();\",\n \"msg.payload = sm.data.hms_format ? sm.sec2hhmmss(sm.data.seconds): sm.data.seconds;\"\n ],\n \"reset\": [\n \"sm.data.time = 0;\",\n \"sm.data.seconds = 0;\"\n ],\n \"status\": {\n \"fill\": {\n \"get\": \"sm.currentState === 'counting' ? 'green' : 'grey';\"\n },\n \"shape\": \"dot\",\n \"text\": {\n \"get\": \"'time ' + (sm.data.hms_format ? sm.sec2hhmmss(sm.data.seconds): sm.data.seconds);\"\n }\n }\n }\n}\n","x":500,"y":1580,"wires":[["f5b21cb6.4b917","19b5c9f2.5c111e"]]},{"id":"d7688d61.80761","type":"comment","z":"da622957.7a8bf8","name":"Uptime Calculation","info":"","x":370,"y":1840,"wires":[]},{"id":"f7fd7be7.52d78","type":"link out","z":"da622957.7a8bf8","name":"TotalTime","links":["6570b222.6a6c8c","9908bf92.d675f8"],"x":835,"y":560,"wires":[]},{"id":"6fd77f56.c27a78","type":"link in","z":"da622957.7a8bf8","name":"","links":["6dacabd9.11c40c"],"x":115,"y":2020,"wires":[["5519afa5.e7b61"]]},{"id":"6dacabd9.11c40c","type":"link out","z":"da622957.7a8bf8","name":"Downtime","links":["6fd77f56.c27a78"],"x":875,"y":1320,"wires":[]},{"id":"89dfb542.536f98","type":"debug","z":"da622957.7a8bf8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":490,"y":1900,"wires":[]},{"id":"9908bf92.d675f8","type":"link in","z":"da622957.7a8bf8","name":"","links":["f7fd7be7.52d78","5a5a99f4.61a018"],"x":115,"y":1940,"wires":[["5519afa5.e7b61"]]},{"id":"39023bea.9c339c","type":"comment","z":"da622957.7a8bf8","name":"Total Time","info":"","x":150,"y":1900,"wires":[]},{"id":"d7c50fb5.8e092","type":"comment","z":"da622957.7a8bf8","name":"Downtime","info":"","x":140,"y":1980,"wires":[]},{"id":"5519afa5.e7b61","type":"join","z":"da622957.7a8bf8","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":330,"y":1960,"wires":[["89dfb542.536f98","49aab2a4.da7c34"]]},{"id":"311581f8.cee7d6","type":"debug","z":"da622957.7a8bf8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":670,"y":1960,"wires":[]},{"id":"77df5c05.ec9fa4","type":"link in","z":"da622957.7a8bf8","name":"","links":["16e15d3a.8a3bcb","e2b78d97.5eab","3129dd13.ffce6a","d75aea2f.98a96"],"x":215,"y":1740,"wires":[["96f5c632.cbdc28"]]},{"id":"1431d456.9585fc","type":"link in","z":"da622957.7a8bf8","name":"","links":["d24305d.49752f8"],"x":195,"y":760,"wires":[["57a73e2f.bc883"]]},{"id":"8f8e4f91.db64d","type":"change","z":"da622957.7a8bf8","name":"","rules":[{"t":"change","p":"topic","pt":"msg","from":"counting","fromt":"str","to":"stop","tot":"str"},{"t":"change","p":"topic","pt":"msg","from":"stopped","fromt":"str","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":1440,"wires":[[]]},{"id":"7a0a2523.84d74c","type":"function","z":"da622957.7a8bf8","name":"operating","func":"msg.topic=\"operating\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":640,"y":500,"wires":[["957a824.8d04d","f7fd7be7.52d78"]]},{"id":"309c1637.cf2722","type":"function","z":"da622957.7a8bf8","name":"downtime","func":"msg.topic=\"downtime\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":720,"y":1280,"wires":[["fd07da2d.a08d4","6dacabd9.11c40c"]]},{"id":"49aab2a4.da7c34","type":"function","z":"da622957.7a8bf8","name":"","func":"var msg1 = { payload:\"operating\" };\nvar msg2 = { payload:\"downtime\" };\nmsg.payload = msg1 - msg2\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":500,"y":1960,"wires":[["311581f8.cee7d6"]]},{"id":"52a06381.0494c4","type":"influxdb","z":"","hostname":"127.0.0.1","port":"8086","protocol":"http","database":"raspioee","name":"","usetls":false,"tls":""}]
