Can a custom node have a function as a property?
Context:
I have a custom node currently in use that allows for a selection to be made in the config panel via drop down which is a dynamic list of end points. Current behavior is on selection, the endpoint is accessed and the data is parsed and saved to a static property value of the node/config for use downstream.
The Problem:
If the endpoint has had a data change, our saved value in node/config is no longer reflective of the actual endpoint data.
The Desire:
I would like to maintain compatibility with the property name in use, but instead of the property supplying the saved static value, I would like the property to call a function to retrieve/parse/return the data to the caller without introducing a breaking change for current users of the node ideally.
I've tried:
  1. defining a function as the value for the relevant key in defaults
  2. removing the key from defaults, defining the function outside of defaults
Neither has worked.
Is it possible to define a property as a function for a custom node in node-red ?
If the endpoint has updated data, how do you expect to know? Is it that you want your node to query the endpoint every time it receives a msg input?
If so, you don't need to save anything in the Editor, you need to call the endpoint from the runtime instead .
If not, what triggers a new fetch of the data?
