This is how I add external modules to my docker instance for use inside the function node.
This example I'm adding xlsx from sheetjs
Get the ID of the node-red container
$ docker ps
Installing npm module (make sure to change the ID to the one you got from $ docker ps)
$ docker exec -it f534d7069634 /bin/bash
$ cd /data
$ ls
$ npm install --save https://cdn.sheetjs.com/xlsx-0.20.1/xlsx-0.20.1.tgz
edit the settings.js file to use this module.
functionGlobalContext: {
XLSX:require('xlsx'),
now in nodered's function module I can use it like this:
var XLSX = global.get('XLSX');
msg.payload = XLSX.version;
I don't like the new system and installing version specific modules has been an issue for me. Until there is a good howto on the new system, installing inside the editor, I'll keep installing modules the old way.
