how to make a running text on node red?
You mean something like this?:
"id": "8bd4909af00760b3",
"type": "ui_template",
"z": "bd54c6a8.5d776",
"group": "f139e62.e7f4a18",
"order": 3,
"width": "5",
"height": "1",
"format": "<style>\n.scroll-left {\n height: 50px;\t\n overflow: hidden;\n position: relative;\n background: yellow;\n color: orange;\n border: 1px solid orange;\n}\n.scroll-left p {\n position: absolute;\n width: 100%;\n height: 100%;\n margin: 0;\n line-height: 50px;\n text-align: center;\n /* Starting position */\n transform:translateX(100%);\n /* Apply animation to this element */\n animation: scroll-left 15s linear infinite;\n}\n/* Move it (define the animation) */\n@keyframes scroll-left {\n 0% {\n transform: translateX(100%); \t\t\n }\n 100% {\n transform: translateX(-100%); \n }\n}\n</style>\n\n<div class=\"scroll-left\">\n<p>Scroll left... </p>\n</div>\n",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": true,
"templateScope": "local",
"className": "",
"x": 840,
"y": 480,
"id": "f139e62.e7f4a18",
"type": "ui_group",
"name": "Wohnzimmer",
"tab": "5aa95dc.23f2224",
"order": 1,
"disp": false,
"width": "7",
"collapse": false,
"className": ""
"id": "5aa95dc.23f2224",
"type": "ui_tab",
"name": "Home",
"icon": "dashboard",
"disabled": false,
"hidden": false
where should i put it on, sorry im newbie at node red
That would be basic HTML. Just pass a Marquee tag into a dashboard text node.
thanks! OriolFM its solved i forgot we can put html too in node red
It's fine, sometimes people tend to overthink simple stuff.
In the beginning I had a lot of problems scaling my dashboard because I had to display many fields from several machines, and I was placing a lot of text nodes for each machine, assigning them to a tab and then to a group, adding spacers, and so on... it was painful.
In the end, I realised I could just prepare a single HTML string per machine, dimensioned like a table, and use a single text node per machine to display all the parameters. Much easier and simpler, and I could replicate the same setup by just using the same function node or subflow to prepare the HTML.
I thought about the Marquee tag because I already came up with that HTML thing earlier in my workflow, but I have to admit, it took me a while to figure it out.
