Hi there, I'm new to nodered and was just starting out, I am trying to use NodeRed to receive data from a ESP8266 connected to a QMC5883L (Magnetic compass sensor).
I am unsure of what issue but when I tried to run " npm install --save nodejs-qmc5883l " I will get and error. Any help or suggestions would be greatly appreciated. Thank you in advance.
npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
> nodejs-qmc5883l@2.0.0 install C:\Users\Josia\node_modules\nodejs-qmc5883l
> node-gyp rebuild
C:\Users\Josia\node_modules\nodejs-qmc5883l>if not defined npm_config_node_gyp (node "C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
gyp ERR! UNCAUGHT EXCEPTION
gyp ERR! stack Error: spawn C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\15.0\Bin\MSBuild.exe ENOENT
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:249:19)
gyp ERR! stack at onErrorNT (internal/child_process.js:442:16)
gyp ERR! stack at processTicksAndRejections (internal/process/task_queues.js:84:9)
gyp ERR! System Windows_NT 10.0.19043
gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
gyp ERR! cwd C:\Users\Josia\node_modules\nodejs-qmc5883l
gyp ERR! node -v v12.2.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! This is a bug in `node-gyp`.
gyp ERR! Try to update node-gyp and file an Issue if it does not help:
gyp ERR! <https://github.com/nodejs/node-gyp/issues>
npm WARN ws@8.2.3 requires a peer of bufferutil@^4.0.1 but none is installed. You must install peer dependencies yourself.
npm WARN ws@8.2.3 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must install peer dependencies yourself.
npm WARN Josia No description
npm WARN Josia No repository field.
npm WARN Josia No license field.
npm ERR! code ELIFECYCLE
npm ERR! errno 7
npm ERR! nodejs-qmc5883l@2.0.0 install: `node-gyp rebuild`
npm ERR! Exit status 7
npm ERR!
npm ERR! Failed at the nodejs-qmc5883l@2.0.0 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
node --version && npm --version
v12.2.0
6.9.0
