Cannot seem to start Node-RED Docker custom container
I need help with starting my container.
I followed all the steps here https://nodered.org/docs/getting-started/docker to build my image.
However, when I try to start/run the container it exits with the following error in the logs.
Here is my Dockerfile:
FROM nodered/node-red:latest
COPY package.json .
RUN npm install --only=production
# Copy _your_ Node-RED project files into place
COPY settings.js /data/settings.js
COPY flows.json /data/flows.json
# Start the container normally
# CMD [ "npm", "start", "--", "--userDir", "/data"]
CMD ["npm", "start"]
docker logs 75f4b1582b1d
> node-red-project@0.0.1 start /usr/src/node-red
> node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data" "npm" "start"
internal/modules/cjs/loader.js:638
    throw err;
Error: Cannot find module '/usr/src/node-red/node_modules/node-red/red.js'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    at startup (internal/bootstrap/node.js:283:19)
    at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! node-red-project@0.0.1 start: `node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data" "npm" "start"`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the node-red-project@0.0.1 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR!     /usr/src/node-red/.npm/_logs/2020-05-06T12_11_18_034Z-debug.log
Can someone please help! Why would that module be missing if I am using the official base image. What am I doing wrong?
Thanks!
The page you linked contains a lot of information. Which specific steps did you follow ? You say "to build my image" are you creating your own container ?
Yes I am building my own image using docker build.
I have posted my Dockerfile in the message above.
Thanks!
Have you verified that the path is correct and that node-red is indeed installed there?
ok thanks for that hint @afelix. I did and there wasn't any node_module/node-red.
So I figured my package.json file was over-writing the original and that was messing up the install. So I changed my dockerfile to
COPY package.json /data/
However, now it is not installing the sqlite package I need for my flows. I can of-course go in after the container is up and then re-install the "node-red-node-sqlite" package. Something is missing from the instructions as I should be able to simply take my flow and rebuild a image with everything.
These are the new logs -
> node-red-docker@1.0.6 start /usr/src/node-red
6 May 12:57:47 - [info]
Welcome to Node-RED
6 May 12:57:47 - [info] Node-RED version: v1.0.6
6 May 12:57:47 - [info] Node.js  version: v10.20.1
6 May 12:57:47 - [info] Linux 4.18.0-193.10.el8.x86_64 x64 LE
6 May 12:57:48 - [info] Loading palette nodes
6 May 12:57:48 - [info] Settings file  : /data/settings.js
6 May 12:57:48 - [info] Context store  : 'memoryOnly' [module=memory]
6 May 12:57:48 - [info] User directory : /data
6 May 12:57:48 - [warn] Projects disabled : editorTheme.projects.enabled=false
6 May 12:57:48 - [info] Flows file     : /data/flows.json
your credentials.
6 May 12:57:48 - [info] Server now running at http://127.0.0.1:1880/
6 May 12:57:48 - [info] Waiting for missing types to be registered:
6 May 12:57:48 - [info]  - sqlitedb
I got it working.
Thanks for all your input.
The package.json file didn't have "node-red" as a dependency and therefore npm wasn't installing the package. Once I added "node-red" to the dependency list I was able to get everything working.
Thanks!
