Can't append JQuery fetch result in Dropdown Box in HTML nodeRED
I am fetching results using JQuery, I can see the results on the console but can't push it into the dropdown box.
        RED.nodes.registerType('uni-red',{
            category: 'Network',
            color: '#baff97',
            defaults: {
            outputs: {value: 1}
            inputs:1,
            outputs:1,
            icon: "Cute-Ball-Go-icon.png",
            label: function() {
                        return this.name || "uni-red";
            labelStyle: function() {
                    return this.name?"node_label_italic":"";
            oneditprepare: function() {
                let url_base ='http://localhost:8080'
                const node = this    $.getJSON('http://localhost:8080/service/fa81c7a/TemperatureController/property/CurrentTemperature',
         function(data){
                     const newOp = (`<option>${data}</option>`)
                      $("#node-input-operation").append(newOp)
</script>
After this I have my normal HTML tags in place.
What is in data? I imagine it's an object since you are calling getJSON.
Example...
$("#node-input-operation").append(`<option value="${data.value}">${data.text}</option>`);
So, on my console I am getting an UUID number from the .get function. Also Can I use node.send() somehow to show the result on nodeRED from script tag?
