I have next example data:
let dataArray = [
tempdata: [
{ time: 1710584361161, temp: 21.1 },
{ time: 1710584371161, temp: 22.0 },
{ time: 1710584381161, temp: 21.5 }
tempdata: [
{ time: 1710584361161, temp: 19.2 },
{ time: 1710584371161, temp: 20.3 },
{ time: 1710584381161, temp: 18.9 }
And then I use this function to format it:
let formattedData = dataArray.map(series => {
return {
topic: series.name, // Label for the series
payload: series.tempdata.map(point => ({
x: new Date(point.time).toISOString(), // Convert to UTC ISO string
y: point.temp // Temperature as y value
msg.payload = formattedData;
So the data I send to the chart looks like this:
But the data doesn't get trough. All I see is this:
These are my chart settings:
How could one get that example data trough to a chart?
jbudd
13 November 2024 11:21
2
The dashboard 2 chart does not need the same x: .., y: .. formatted data as dashboard 1.
Instead you should aim for a flatter data structure like this (you see that data for the two lines do not need to be kept separate)
msg.payload = [
{ name: "room 1", time: 1710584361161, temp: 21.1 },
{ name: "room 2", time: 1710584361161, temp: 19.2 },
{ name: "room 1", time: 1710584371161, temp: 22.0 },
{ name: "room 2", time: 1710584371161, temp: 20.3 },
{ name: "room 1", time: 1710584381161, temp: 21.5 },
{ name: "room 2", time: 1710584381161, temp: 18.9 }
If your data was sourced from an SQL database the query might be as simple as
SELECT name, time, temp FROM tablename
And the chart config is like this
I made this as my message:
But it didn't work.
I noticed that you have dropdown buttons here and I don't:
So I then updated to a newer version. And now I got a lot more options:
But still no data:
Since it was remembering the Y-scale, I deleted the chart object and made a new one. And now finally I get the data
So thanks for you repply! I did earlier try this format also but didn't get it to work. The overall issue was that I had some old version.
jbudd
13 November 2024 11:45
4
Yes, after changing a dashboard widget you have to send an empty array to clear the chart, reload the browser tab, reload it with ctrl f5 or even clear the browser cache.
I think recent changes have improved the behaviour but it's best always to reload.
