Center a mdi-circle in a1 by 3 field
how can I center horizontaly and verticaly a mdi circle in 1 by 3 field.
code below does not work.
<template>
    <div class="my-class">
        <div :style="{color: msg.color || 'black', margin: 'auto' }">
            <i :class="['mdi', msg.icon || 'mdi-help']" aria-hidden="true"></i>
        </div>
    </div>
</template>
<script>
    export default {
  data() {
    return {
</script>
<style>
    .my-class {
        display: flex;
        justify-content: center;
</style>
this is how it looks on dashboard 1
It is centered. But here is a danger in your class naming strategy. If you use "my-class" anywhere else - the last one wins. (And you most probably don't know which will be the last one.)
Use names for classes you can identify to avoid confusion.
many thanks! It works.
But how can I change the size of the circle - like size{2}
For icons (mostly) the font-size is the property to change.
