below, my working template in DB-2.
Now I want to change the size of the text and the icon to be bigger and I want to change the background color. Field size 4x2.
Any help appreciated.
<template>
<div>
<center>
<div :style="{color: msg.color || 'black', margin: 'auto' }">
<i :class="['mdi', msg.icon || 'mdi-help']" aria-hidden="true"></i>
{{ msg.payload }}
</div>
</center>
</div>
</template>
<script>
export default {
data() {
return {
</script>
I want that the icon and text fills the whole width (see picture)
Are you wanting to change those things based on something in msg, or just have them applied all of the time?
If the latter, you can add some CSS in a <style> block at the bottom of your template, e.g:
<style>
.my-class {
font-size: 2rem; /* 2 x the standard font-size */
background-color: red;
text-align: center;
</style>
You can then attach the my-class to your template with:
<template>
<div class="my-class">
{{ msg.payload }}
</div>
</div>
</template>
Note too that I also removed the <center> block as you can use text-align: center in the CSS instead.
Hi Joe,
many thanks for your support!
I have added some lines with the help of the internet.
<template>
{{ msg.payload }}
</div>
</div>
</template>
<script>
export default {
data() {
return {
</script>
<style>
.my-class {
font-size: 2rem;
background-color: "#2F2D2D";
text-align: center;
display: flex;
justify-content: center;
align-items: center;
</style>
now it looks perfect!
one last question:
I want to have a CR after Alarm!!! in "Alarm!!! no smoke detected".
I tried \n, hex code, etc. but it does not work.
CR? Not sure what you are referring to?
Maybe a Breakpoint? If so, <br />
yes, I want a new line or break in my payload like so:
payload: "Alarm!!!
smoke detected"
But it does not work.
this is what I get :
want to inject HTML with your msg.payload, you can tell Vue to parse it like so:
<span v-html="msg.payload"></span>
perfect!!
many thanks, especially on sunday!
Hi, Joe. Do you know if col span works, I need to increase the size of the raws depending of the registers of another table. Example:
Closed. Topic is solved. Latest comment is unrelated.
