i try to change or rewrite a already installed module.
install path under /var/node_modules/node-red-contrib-xxx/lib/xx.js
i try to fix some stuff, but it doesnt take effekt after i saved the file.
is there any node-red cache, or something else ?
how can i made this done.
thx
You also need to restart Node-RED for it to load the changes
Hi, yea i tried this serverall times... no effect.
i stopped, waited and started again.
and i restarted.
code changes has no effect in the dashboard..
the file is changed, if i connect via scp and check the file...
thank you
what were the exact commands you used to stop/start node red?
how did you install node-red?
when in doubt, you could reboot the machine node-red is running on.
An installed module should be in ~/.node-red/node_modules ?
Hi thanks for response,
restart of entire rasberry did it.
thanks.
Try node-red-stop; node-red-start next time
