Hi there,
I am using Deconz for my motion sensors to turn on/off the light.
My problem is that when I am moving fast between the rooms the msg.paypload.presence of some motion sensors is still "true" although I left the room a couple of seconds ago.
This behavior is not bad at all because it "slows down" the presence detection and prevents the lights to turn off to fast.
When I am moving between the rooms I am searching for a method to set a deconz sensor to false (override the current status of the sensor).
For short: I am moving from the living room to the corridor to the kitchen. When I arrive in the kitchen I want to set the msg.payload.presence of the corridor to false so that it can be immediately set back to true when I am back in the corridor.
Can anybody help here?
Thank you
Greets from Germany
Daniel
