I am reading in values from Kepware and then joining the response into a key/value object.
How do I rename the keys from msg.topic to a custom label I assign?
There are multiple ways.
You could use a change node after the join to move the properties to a better names.
You could pass the msg through a function that splits the topic on . and keeps the last part. Something like this (untested)
const payload = msg.payload;
const result = {};
for (let key in payload) {
if (payload.hasOwnProperty(key)) {
const newKey = key.split('.').pop();
result[newKey] = payload[key];
msg.payload = result;
Thanks for your response!
Sorry on slow return, busily trying to replace our current tagging engine with node-red.
In the end, I went with your first recommendation on using a change node. For anyone else who comes after, this is how I set it up to update topic name coming from OPC UA Server read:
Using a regular expression search allowed me to ignore the rest of the nodeId returned and just focus on the tag names.
Thanks again!!
