Change node to function node (newbie problem)
I would like to do the same thing as this node in a function node and I can't do it.
can you help me
msg.payload = msg.payload.e2movielist;
An I missing something?
Thank you Steve,
That's what I thought but I had the answer
msg.payload : undefined
undefined
I copied your sentence as it is. Indeed it works
Perhaps a spelling mistake? Also, remember, JavaScript is case sensitive.
Also, in case you don't already know, to avoid typos, you can you the copy path button...
canned text...
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
I found my problem.
the variable to be analyzed was too large (>60000 chr).
(I had simplified the problem to ask my question)
msg.payload = msg.payload.e2movielist.e2movie;
it's ok
msg.payload = msg.payload.e2movielist.e2movie.e2title;
return a "indefinited" error
What is surprising is that this change node returns the correct result
thank you for the time you spent answering me
