Please make it so that the size and width select dialogs stay open until clicked. Or make them input fields. The current hover method is inconvenient and not accessible to everyone.
By clicking on the numbers when the window is open will open a second dialog where you can type in the numbers.
I take the opportunity to ask something related to this,
Is it possible to adjust the size of a group to 100% of the window?
(for example, change this value with css)
Thank you for your reply. I'm not sure if I've missed that or not. However, that doesn't solve the main issue if you need to use an on-screen keyboard (like I do). When you move the mouse cursor away the dialog goes away also.
