Change settings.js
my node needs the nodes context storage to be persistent, for that, I can set
contextStorage to localfilesystem in settings.js.
can I change that setting from my node? how?
in the docs it is mentioned that you can use multiple context storages:
contextStorage: {
   default: "memoryOnly",
   memoryOnly: { module: 'memory' },
   file: { module: 'localfilesystem' }
how do I use a contextStorage different to default for my nodes context?
If it is not possible to change these setting from code, is there a recommended way to tell users about the required settings?
you have to edit the settings.js file and restart node-red.
For an explaination of how it works, read A guide to understanding 'Persistent Context'
great write up! thanks! should have searched the forum before asking :wink:
