Change Title color to group Header . Dashboard
Continuing the discussion from How to add icon to card header. Dashboard 2:
Can we change also the color of the group Title ?
/* define any styles here - supports raw CSS */
    .v-card-title {
        color: red;
Great it works
what about the icon color ?
Thanks a lot
Done !!!
found the tip ..
Hello, I am currently rebuilding Dashboard1 into Dashboard2. I have painfully learned that I cannot display colored icons in the text output.
I have found this example here and now I would like to modify it so that:
a) the icons are displayed in color, and
b) not as a card header, but as a separate element within the card.
This way, I can use the pictogram to see the current state of various home automation systems at a glance - for example, green means good, red means bad, blue means off, etc.
Can anyone give me some initial guidance on how to achieve this?
        "id": "2be3bc674c163d0b",
        "type": "inject",
        "z": "96021c4f811b5928",
        "props": [
                "p": "title",
                "v": "Winter",
                "vt": "str"
                "p": "icon",
                "v": "mdi-snowflake-thermometer",
                "vt": "str"
                "p": "color",
                "v": "blue",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 190,
        "y": 60,
                "de4a108eb3e6cdf6"
        "id": "7984f3d787ad6014",
        "type": "inject",
        "props": [
                "p": "title",
                "v": "Sommer",
                "vt": "str"
                "p": "icon",
                "v": "mdi-coolant-temperature",
                "vt": "str"
                "p": "color",
                "v": "green",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 190,
        "y": 120,
                "de4a108eb3e6cdf6"
        "id": "de4a108eb3e6cdf6",
        "type": "ui-template",
        "group": "d0ee23241087db79",
        "page": "",
        "ui": "",
        "name": "Card header icon and title",
        "order": 1,
        "width": 0,
        "height": 0,
        "head": "",
        "format": "<template>\n   <Teleport v-if=\"mounted\" :to=\"target\">\n        <div class=\"v-card-item__append\">\n            <v-icon aria-hidden=\"false\">{{icon}}</v-icon>            \n        </div>\n        <div class=\"v-card-item__prepend\">\n            <div class=\"v-card-title\">{{title}}</div>\n        </div>\n   </Teleport>\n</template>\n\n<script>\n    export default {\n        data() {           \n            return {\n                mounted:false,\n                target:\"\",\n                icon:\"mdi-account\",\n                title:\"Dynamic title\"     \n            }\n        },\n        computed: {        \n            \n        },\n        watch: {\n            msg: function () {\n                if(this.msg?.title != undefined){\n                    this.title = this.msg.title\n                }\n                if(this.msg?.icon != undefined){\n                    this.icon = this.msg.icon\n                }\n            }\n        },\n        mounted(){            \n            this.target = '#nrdb-ui-group-'+this.props.group+' .v-card-item'\n            this.mounted = true            \n        }\n    }\n</script>\n<style>\n    .hidden-template{\n        display:none !important;\n    }\n</style>\n",
        "storeOutMessages": true,
        "passthru": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "hidden-template",
        "x": 490,
        "y": 80,
        "id": "d0ee23241087db79",
        "type": "ui-group",
        "name": "Temperatur",
        "page": "e68fa6b2b27f0ec4",
        "width": "6",
        "height": "1",
        "order": 3,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false",
        "groupType": "default"
        "id": "e68fa6b2b27f0ec4",
        "type": "ui-page",
        "name": "Teichsteuerung",
        "ui": "f96401822df0a597",
        "path": "/page4",
        "icon": "home",
        "layout": "grid",
        "theme": "e69c750bbe40bb7a",
        "breakpoints": [
                "name": "Default",
                "px": "0",
                "cols": "3"
                "name": "Tablet",
                "px": "576",
                "cols": "6"
                "name": "Small Desktop",
                "px": "768",
                "cols": "9"
                "name": "Desktop",
                "px": "1024",
                "cols": "12"
        "order": 7,
        "className": "",
        "visible": true,
        "disabled": false
        "id": "f96401822df0a597",
        "type": "ui-base",
        "name": "My Dashboard",
        "path": "/dashboard",
        "appIcon": "",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false,
        "showPageTitle": true,
        "navigationStyle": "default",
        "titleBarStyle": "default"
        "id": "e69c750bbe40bb7a",
        "type": "ui-theme",
        "name": "Default Theme",
        "colors": {
            "surface": "#ffffff",
            "primary": "#0094ce",
            "bgPage": "#eeeeee",
            "groupBg": "#eeeeee",
            "groupOutline": "#cccccc"
        "sizes": {
            "density": "default",
            "pagePadding": "12px",
            "groupGap": "12px",
            "groupBorderRadius": "4px",
            "widgetGap": "12px"
Try
<template>
   <Teleport v-if="mounted" :to="target">
        <div class="v-card-item__append">
            <v-icon aria-hidden="false" :color = "iconColour">{{icon}}</v-icon>
        </div>
        <div class="v-card-item__prepend">
            <div class="v-card-title" >{{title}}</div>
        </div>
   </Teleport>
</template>
<script>
    export default {
        data() {
            return {
                mounted:false,
                target:"",
                icon:"mdi-account",
                iconColour: 'black',
                title:"Dynamic title"
        computed: {
        watch: {
            msg: function () {
                if (this.msg?.color != undefined) {
                    this.iconColour = this.msg.color
        mounted(){
            this.mounted = true
</script>
<style>
    .hidden-template{
</style>
You can also define various style classes to adjust other attributes of the icon.
