Change Top Logo on the Left
Hi People,
Version: Node-RED version: v3.0.2
I am trying to change the top logo on the left, I followed the documentation, but it is not working.
I followed this doc:
But it did not worked,
What I did:
I added the files into my project under a folder /static/logo.png
I configured the settings.js like this:
httpStatic: "static",
I configured the editor-theme like that:
            header: {
                title: "XYZ",
                image: "logo.png"
But the original logo is never replaced for the new one, when I checked the running UI, I can see the following image url address and never the one that I had configured:
Please, anyone could help?
Edgar
You need to use the full pathname of the logo file
            header: {
                title: "XYZ",
                image: "/home/username/.node-red/static/logo.png"
https://discourse.nodered.org/t/custom-div-banner-above-the-editor/52284
Edit - I just checked and it does work with the full pathname, the value of httpStatic is not used for this.
Hey @jbudd
In the end I made it work, and in order to avoid keep this information fixed, I managed to use as the follow:
            header: {
                title: " ",
                image: __dirname + "/static/logo.png",
With that I am able to generate a more dynamic way to move the logo working in any environment or even a container
I'm glad you got it working.
Maybe you could post your complete solution here for the benefit of others?
