inst-160601221226.pdf (607.2 KB)
Hi all, I wanna change the logo when login to Node-red but I don't know where is this link
"image: "/absolute/path/to/login/page/big/image"
to change the image?
Hi @trintp1999
to change the login logo you need to:
- create the image you want to use. It should be 256px x 256px
- Edit your settings file and edit the
editorThemesection to include:
editorTheme: {
login: {
image: "/absolute/path/to/login/page/big/image" // a 256x256 image
- Replace
/absolute/path/to/login/page/bin/imagewith the full path to the image you want to use. - Restart Node-RED
https://nodered.org/docs/user-guide/runtime/configuration#editor-themes
I have an image named "abc" in D:\image\abc.png
So I replace image: "/absolute/path/to/login/page/big/image" to image: "D:\image\abc.png" but it's not true.
Try changing the \ for / - D:/image/abc.png
It's still not true
Did you restart Node-RED after making that change?
Which settings file are you editing? Have you checked it is the settings file Node-RED is actually using? Node-RED logs the full path to its settings file when it starts.
