Change userdir of docker image
the docker images in the node red docker hub has a command built in that starts the node red with the user dir of /data . I would like to change that to make it /home what is the best way to achieve this? Can i somehow avoid making my own copy of the docker image so that i wont have trouble upgrading to newer ones,
Best regards,
Why would you want that? I'm curious.
thanks for your interest. I am using microsoft azure platform and web app for containers service.
It automatically persists /home folder for docker containers and nothing else. I would like to utilize this feature specifically.
the project is hosted here - https://github.com/node-red/node-red-docker - you can use the docker-custom to build your own image if you like.
I would probably make that /home/nrdata or some such rather than pushing everything into the root home folder.
I'm no Docker expert by any means but I think that you would need to build your own docker image to get this to work?
Thank you all, i ended up using @dceejay s answer to build my own custom image and uploading to docker hub.
