Can anyone please guide me about the following:
I have my node red project in which i had made some customization in flow.json,settings.js and deploy.js files.
Now i want to install this project to docker with my customization.
I am new to Docker as well that's why i followed below link :
Can u please guide me that how can i replace the existing flow.json ,setting.js and deploy.js with my customize files.
You should mount your files to an external data volume - see https://nodered.org/docs/getting-started/docker - section "Using a Host Directory for Persistence (Bind Mount)" when starting docker - this is used as the user directory.
My Node Red project is located in following directory :
D:\PreconnectDemo\node-red-master\node-red-master
Now i want to create the imge of this project and want to run that in a container.
How should i do that?
Can u please help me out ?
@dceejay @knolleary
