How can I make projects in Running Node-red under Docker
I aleady make projects Running Node-red on locally computer
I'm sorry my Englilsh.
I don't know even if I read it.
I just save flows.JSON now.
You are going to need to supply a LOT more information about what you've tried and how it didn't work.
The link clearly explains how to run Node-RED in Docker, if you have an existing flow you have a couple of options
flows.json file and add it to a volume mounted on /data in the containerBut without knowing what you've tried and what you already know about running Docker containers, it's really hard to know how to guide you
