Changing global variables
All,
I am new on Node-Red, thus I am sorry if the question is too stupid. I used node-red to build a Chatbot app that uses "text to speech" (voice) capabilities. I have defined a global variable called "speechOnOff", and I set it to "off" initially. As this is a chatbot, I want the users to commands the voice to be on / off by typing a simple sentence "speech on" or "speech off".
My idea is to change the global variable "speechOnOff" dynamically whenever the user commands it.
Is that possible to change a global variable in any function node different form the one I used to set it initially? I tried but I got an error message.
thanks a lot.
Indeed, that is possible and should work. Please detail what is the error message you got so as we can understand and try to help you to find a fix.
Thanks a lot Andrei. I declare the variable like that:
NODE 1: Initial Node
var publicVariables = {
    speechOnOff: "Off"
global.set("publicVariables", publicVariables);
NODE 2: Then on a second node I test the command, and depending on what it is I set the same global variable to "On" or "Off":
    if (msg.message == "speech on") {
            speechOnOff: "On"
    else if (msg.message == "speech off") {
            speechOnOff: "Off"
Finally on third node I checked if the same variable is "on" or "off":
var publicVariables = global.get("publicVariables").publicVariables;
if (publicVariables.speechOnOff == "On") {
    output=msg.payload;
    msg.payload = {};
    msg.payload.output = {text: [output]}
    node.warn(msg.payload.output);
    node.warn("Conversation output is:\n" + JSON.stringify(msg.payload))
    /* node.send([null,msg]); */
    output = msg.payload.output.text.join(' ');
    msg.payload = output;
And this is the error I got: TypeError: Cannot read property 'speechOnOff' of undefined, which heppens at the third node.
In your first two nodes, you set publicVariables to be an object that looks like this:
   speechOnOff: "on/off"
In your third node, you get the property with this:
You are getting the publicVariables global context property and then trying to access a property of that object called publicVariables - which doesn't exist.
So that line should just be:
var publicVariables = global.get("publicVariables");
Thanks a lot. I do not have the error any more. One more question: at the second node, for me to change the value of the global variable, is it correct the code below? I am asking, as it seems the variable is not being changed.
speechOnOff: "On"
(quick tip, put triple backticks - ``` - before and after any code snippets so that they display properly - I've edited your previous post to add them)
The code is okay - so if it isn't doing what you think, I'd suggest adding some debug statements to check what you're getting. For example, are you sure msg.message is the property to be testing?
var publicVariable;
// log `msg.message` to debug sidebar so you can see what you have
node.warn(msg.message);
    publicVariables = {
        speechOnOff: "On"
    publicVariables = {
        speechOnOff: "Off"
Thanks a lot. I will do it. You are great.
Indeed nothing wrong with the code. I tested your second function and it is loading the global variable with an object according to the value of msg.message
r-001
[{"id":"f6a0a4b4.33beb8","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"248936c9.f4b12a","type":"debug","z":"f6a0a4b4.33beb8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"check","x":870,"y":360,"wires":[]},{"id":"3cef16e4.3c021a","type":"function","z":"f6a0a4b4.33beb8","name":"Second Function","func":"\nif (msg.message == \"speech on\") {\n    \n    var publicVariables = {\n        speechOnOff: \"On\"\n    }\n    global.set(\"publicVariables\", publicVariables);\n}\nelse if (msg.message == \"speech off\") {\n    \n    var publicVariables = {\n        speechOnOff: \"Off\"\n    }\n    global.set(\"publicVariables\", publicVariables);\n}\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":280,"wires":[["ddc8ec64.70f6"]]},{"id":"975438f6.3aa918","type":"inject","z":"f6a0a4b4.33beb8","name":"","topic":"","payload":"speech on","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":260,"wires":[["3f3265e9.a6205a"]]},{"id":"771aa6ad.91b118","type":"inject","z":"f6a0a4b4.33beb8","name":"","topic":"","payload":"speech off","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":300,"wires":[["3f3265e9.a6205a"]]},{"id":"3f3265e9.a6205a","type":"change","z":"f6a0a4b4.33beb8","name":"","rules":[{"t":"set","p":"message","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":280,"wires":[["3cef16e4.3c021a"]]},{"id":"ddc8ec64.70f6","type":"function","z":"f6a0a4b4.33beb8","name":"Retrieve value from global context","func":"msg.check = global.get(\"publicVariables\");\nreturn msg;","outputs":1,"noerr":0,"x":640,"y":360,"wires":[["248936c9.f4b12a"]]}]
Thanks Andrei. Much appreciated.
