Changing the Color and Font of the number shown by the number input widget
Is there a simple example of changing the fonts and colors of both the label and the number independent of each other when using the number input widget for dashboard 2.0?
Regards,
Roger
If all you want is to set these styles once, use a CSS type ui-template:
.nrdb-ui-number-input .v-field-label span {
    color: green;
    font-family: "Courier new";
.nrdb-ui-number-input .v-field__input {
    color: blue;
    font-family: "Comic sans ms";
To change them dynamically and independently set up class names in the template for each:
.redlabel .v-field-label span {
    color: red;
    font-family: "Segoe UI";
.bluelabel .v-field-label span {
    color: blue;
    font-family: "Helvetica";
.greeninput .v-field__input {
    color: green;
.goldinput .v-field__input {
    color: gold;
    font-family: "Times New Roman";
And pass a message to the node with msg.ui_control like this
"class": "redlabel greeninput"
I really appreciate the effort you made to help me out. Thank you and Merry Xmas. I will follow up with you a little later. Do you get on Discord at all I would like to show you how my Thermostat is currently working.
