Changing the line width in a multi line chart
I am displaying several charts in an aggregated line diagram. Node-red-contrib-aggregator is used here. However, the charts are displayed in a very thick line width. Is it possible to make the line thickness thinner?
I use nodered 3.1.9
Regards
Joachim
Hey guys, it can't be that nobody can help me here. Get off your Olympus and help a beginner
Maybe this thread can help you out
I have integrated ui_control into my function. The line thickness has improved. However, I get bold measuring points. In addition, a background color is added to the individual graphs.
function:
var topic;
var payload;
var ui_control;
for (let i = 0; i < 6; i++) {
    switch (i) {
        case 0:
                topic = null;
                payload = []; // clear chart
                break;
        case 1: topic = 'PV [W]';
                payload = 0;
                break;
        case 2: topic = 'Hausverbrauch [W]';
                payload = 0;
                break;
        case 3: topic = 'Netz [W]';
                payload = 0;
                break;
        case 4: topic = 'Akku [W]';
                payload = 0;
                break;
        case 5: topic = 'Wallbox [W]';
                payload = 0;
                break;
        **ui_control = { "options": { "elements": { "line": { "borderWidth": 1 } } } }**
    var newmsg = {payload:payload,topic:topic,ui_control:ui_control};
    node.send(newmsg);
return;
The diagram then looks like this:
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
   code goes here
You can edit and correct your post by clicking the pencil :pencil2: icon.
As to your issue, try using the ui_control object from the post marked as the solution.
Thanks for the info and yes, it looks better now
