Hello!
Please any idea on how I can change the font size of legend, x and y axes of a line chart. I’ve succeeded in changing the line thickness, but the legend and axes are not quite visible.
Please specify what ui node you are using and update the category/tags accordingly so that people can better respond. Thanks.
I used a chart ui node and function node which modifies the thickness of the lines as required.
If you copy the javascript in your function node and paste it here using the </> button
Then people can copy, test and adjust your code before advising you how to achieve your desired result.
Alternatively we could laboriously re-type the code shown in your picture before testing and adjusting it.
(Or of course, not)
Noted.
I've also tried this with the template node, but just the label section has appended to my chart,
<style>
.chart>div>.label{
font-size : 100px !important ;
font-weight : bold !important ;
text-color :#f9f9f9f9 !important;
.chart>div>.legend{
background : #f9f9f9f9 !important;
padding : 15px !important;
.chart>div>.legend>div>.item{
font-size : 36px !important;
color : gold !important;
.chart>div>.legend-item-symbol{
background-radius : 0 !important;
.chart > div > .axes{
color : purple !important;
</style>
For the line thickness, the function node handles that quite better:
msg.ui_control = {
options: {
elements: {
line: {
borderWidth : 15,
fill : false
Below is the image of what I've achieved so far, the x and y elements are not quite visible and so does the legend.
Thanks for the update.
I assume from your other posts that this is a Dashboard v2 chart (@flowfuse/node-red-dashboard) not Dashboard v1 (node-red-dashboard).
Your axis labels do seem to be too small.
Are you displaying the chart on a particularly high resolution screen?
I have tried and failed to style any part of the Dashboard v2 chart widget so I'm sorry I can't suggest anything useful.
The developers do read and respond to forum posts, maybe they will advise you.
Thank you
