Chart js plugin pan mode is not available
I am using chart js and chart plugin in template node to implement the chart, I found the zoom feature is normal while the pan feature is not available. And I tried several ways to change the settings in plugin, it did not work.
And the Mouse dwon/up event can be captured by document.getElementById('myChart'), but the pan feature is still not working.
Here is my code, any idea about this problem? I am using dashboard2.0 @flowfuse/node-red-dashboard 1.26.0
<!-- 容器用于渲染图表 -->
<div style="width:100%; height:300px;">
  <canvas id="myChart"
  pointer-events: auto></canvas>
</div>
<!-- 引入 Chart.js 及其缩放插件 -->
<script src="https://cdn.jsdelivr.net/npm/chart.js@4.4.2"></script>
<script src="https://cdn.jsdelivr.net/npm/chartjs-plugin-zoom@2.0.1"></script>
<!-- 初始化图表 -->
<script>
  Chart.register(ChartZoom);
  // 获取 Canvas 上下文
  const ctx = document.getElementById('myChart').getContext('2d');
  const canvas = document.getElementById('myChart');
  ['mousedown', 'mouseup'].forEach(event => {
  canvas.addEventListener(event, (e) => {
  console.log(`Mouse dwon/up event: ${event} at (${e.clientX}, ${e.clientY})`);
  e.stopPropagation();
  // 初始化数据(默认值,可通过 msg 动态更新)
  let chartData = {
    datasets: [{
      label: 'Sample Data',
      data: [{ x: 1, y: 5 }, // 第一个点 (X=1, Y=5)
      { x: 2, y: 10 },
      { x: 3.5, y: 6 },
      { x: 4, y: 2 },
      { x: 3, y: 8 }],
      borderColor: 'rgb(75, 192, 192)',
      showLine: true,
      tension: 0.1
  // 创建图表
  const myChart = new Chart(ctx, {
    type: 'line',
    data: chartData,
    options: {
      responsive: true,
      interaction: {
      mode: 'nearest', // 关键:不让 tooltip 抢事件
      intersect: false// 避免鼠标事件冲突
      scales: {
      x: {
      type: 'linear', // X 轴为线性轴(适用于数值型数据)
      position: 'bottom'
      y: {
      type: 'linear' // Y 轴为线性轴
      plugins: {
        zoom: {
          pan: {
          enabled: true, // 启用拖动平移
          mode: 'xy', // 同时平移 X 和 Y 轴
          modifierKey: null, // 不需要按键直接拖动
          onPanStart({chart}) { console.log('paning'); },
          onPan({chart}) { console.log('paning'); },
          threshold: 1// 拖动距离阈值,防止误触
          zoom: {
            wheel: { enabled: true },    // 启用滚轮缩放
            pinch: { enabled: true },    // 启用 pinch 缩放(触摸设备)
            mode: 'xy' ,                // 同时缩放 X 和 Y 轴
            drag: { enabled: false } // 关闭框选缩放
</script>
Add this script before chartjs
<script src="https://cdn.jsdelivr.net/npm/hammerjs@2.0.8"></script>
By the way. What is like to live in China? I would like to visit it one day
Why does this Kanji轴 repeat in the end of this phrase 轴为线性轴? And how are you able to memorize all these Kanji! I guess all Chinese are geniuses after all haha
I tried to mimick the sound of that phrase in Google translator and it didn’t work. I kept getting 九尾。(Jiǔ wěi.) when trying to repeat jhóu wèi. I guess my brain can't adapt to chinese anymore :frowning:
Hi, Allan
Thank you very much, it works. I tried to solve this entire day and failed.
The life in China? I would say it is busy and quick sometimes. But China has various life style and food in different cities, it will be fun to experience them. Welcome to China.
The 轴 means axis in English, that is why it repeats at the code. It will be easy to learn Kanji start from Childhood, otherwise, it would be difficult to adapt its pronunciation and writing.
