Clear Level Graph
Hi, I created some text nodes and level graphs to display my data from mysql. It works fine and I got the result I wanted:
but when I delete the hand sanitizer dispenser 1 (on my data base) this is what I get:
The values on the text nodes clear, but my graph keeps displaying the last value he got, instead of 0ml. Is there something I can do?
You could check incoming message for values of the display properties, and if null or undifined set payload to 0. Depending on how your flow works.
Hi thank you very much for you answer
I've already tried the following code on my template node
if (msg.payload.dispenser == undifined)
    msg.payload=0;
else{
Select available From left_capacity where dispenser=1;
but I have an error. My value format for my graph is {{msg.payload[0].available}}
What are the label properties ml and %?
there the ones you need to check are null or undefined.
you have misspelled the undefined
Here's my flow
[{"id":"a17825bb.8450c8","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"5de27696.ff4898","type":"mysql","z":"a17825bb.8450c8","mydb":"b1fe5a2d.d1e8a8","name":"DB","x":530,"y":420,"wires":[["6ed4ebf9.258834"]]},{"id":"36704f96.9e557","type":"inject","z":"a17825bb.8450c8","name":"query","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"3","crontab":"","once":true,"onceDelay":"0.1","topic":"","payload":"","payloadType":"date","x":150,"y":420,"wires":[["a4eec39f.54aff"]]},{"id":"a4eec39f.54aff","type":"template","z":"a17825bb.8450c8","name":"Format query 1","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Select dispenser From left_capacity;","output":"str","x":360,"y":420,"wires":[["5de27696.ff4898"]]},{"id":"6ed4ebf9.258834","type":"switch","z":"a17825bb.8450c8","name":"","property":"payload.dispenser","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"msg"},{"t":"eq","v":"2","vt":"msg"}],"checkall":"true","repair":false,"outputs":2,"x":730,"y":420,"wires":[["136fa0cc.3aa51f"],["7ba6e969.e9d258"]]},{"id":"3c0029ed.38c8e6","type":"ui_gauge","z":"a17825bb.8450c8","name":"Available Hand Sanitizer Dispenser 1","group":"19853017.10f43","order":3,"width":"6","height":"6","gtype":"wave","title":"Available Hand Sanitizer","label":"ml","format":"{{msg.payload[0].available}}","min":0,"max":"3000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"500","seg2":"1500","x":1290,"y":240,"wires":[]},{"id":"4ac8b830.edddc8","type":"mysql","z":"a17825bb.8450c8","mydb":"b1fe5a2d.d1e8a8","name":"DB","x":1050,"y":240,"wires":[["3c0029ed.38c8e6"]]},{"id":"136fa0cc.3aa51f","type":"template","z":"a17825bb.8450c8","name":"Format query 1","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Select available From left_capacity Where dispenser=1;","output":"str","x":880,"y":240,"wires":[["4ac8b830.edddc8"]]},{"id":"55c59219.6f86cc","type":"debug","z":"a17825bb.8450c8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1250,"y":360,"wires":[]},{"id":"fa0a2b79.466ba8","type":"ui_gauge","z":"a17825bb.8450c8","name":"Available Hand Sanitizer Dispenser 2","group":"9889b5c8.a71e68","order":3,"width":"6","height":"6","gtype":"wave","title":"Available Hand Sanitizer","label":"ml","format":"{{msg.payload[0].available}}","min":0,"max":"3000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"500","seg2":"1500","x":1350,"y":400,"wires":[]},{"id":"351e1936.6ed0f6","type":"mysql","z":"a17825bb.8450c8","mydb":"b1fe5a2d.d1e8a8","name":"DB","x":1110,"y":420,"wires":[["fa0a2b79.466ba8","55c59219.6f86cc"]]},{"id":"7ba6e969.e9d258","type":"template","z":"a17825bb.8450c8","name":"Format query 1","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Select available From left_capacity Where dispenser=2;","output":"str","x":960,"y":420,"wires":[["351e1936.6ed0f6"]]},{"id":"b1fe5a2d.d1e8a8","type":"MySQLdatabase","name":"projecto","host":"127.0.0.1","port":"3306","db":"projecto","tz":"nodered","charset":""},{"id":"19853017.10f43","type":"ui_group","name":"Dispensador 2","tab":"30837847.88be68","order":2,"disp":true,"width":"6","collapse":false},{"id":"9889b5c8.a71e68","type":"ui_group","name":"Dispensador 3","tab":"30837847.88be68","order":3,"disp":true,"width":"6","collapse":false},{"id":"30837847.88be68","type":"ui_tab","name":"Gráficos","icon":"dashboard","order":9,"disabled":false,"hidden":true}]
my code on my data base for this is:
CREATE VIEW left_capacity
AS
SELECT max(time_stamp) AS calendar,
       id_dispenser AS dispenser,
       full_capacity AS capacity,
       greatest(full_capacity - nr_pumps * 3, 0) AS available
       FROM records r
            INNER JOIN dispenser d
                       ON d.id_disp = r.id_dispenser
       GROUP by id_dispenser;
create view percentage_left_capacity AS
SELECT dispenser,
((left_capacity.available/left_capacity.capacity)*100) AS percentage
From left_capacity;
Thanks, but it's just misspelled in here, when I copied and re-writed everything because my original code is not in english. I just checked and I have it right on the original one :slight_smile:
Can we see a full debug message after the sql query before the gauge node of the deleted database entry?
After deleting dispenser 1 I get this on my debug message on the last sql query
Which node is that coming out of? I don't think that is coming from the database node.
What is coming from the database node?
sorry, my bad, out of the data base
I have this
simple fix catch the error caused by empty db return
eg.
[{"id":"bfc7d213.f19168","type":"change","z":"5a245aa1.510164","name":"","rules":[{"t":"set","p":"payload[0].available","pt":"msg","to":"$count(payload) < 1 ? 0 : payload[0].available","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":940,"wires":[["ebc37340.ddfd9","af19c8b9.373f08"]]},{"id":"6b2ccd77.4da4cc","type":"function","z":"5a245aa1.510164","name":"simulate bad result from db","func":"msg.payload = [];\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":360,"y":880,"wires":[["af19c8b9.373f08","bfc7d213.f19168"]]},{"id":"ebc37340.ddfd9","type":"ui_gauge","z":"5a245aa1.510164","name":"Available Hand Sanitizer Dispenser 1","group":"8b5cde76.edd58","order":3,"width":"6","height":"6","gtype":"wave","title":"Available Hand Sanitizer","label":"ml","format":"{{msg.payload[0].available}}","min":0,"max":"3000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"500","seg2":"1500","x":760,"y":940,"wires":[]},{"id":"af19c8b9.373f08","type":"debug","z":"5a245aa1.510164","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":730,"y":820,"wires":[]},{"id":"c45993.1bd30e7","type":"inject","z":"5a245aa1.510164","name":"bad request","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":880,"wires":[["6b2ccd77.4da4cc"]]},{"id":"2385f349.ef9804","type":"inject","z":"5a245aa1.510164","name":"set level 1100","props":[{"p":"payload[0].available","v":"1100","vt":"num"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":320,"y":1020,"wires":[["ebc37340.ddfd9"]]},{"id":"8b5cde76.edd58","type":"ui_group","name":"","tab":"8f03e639.85956","order":1,"disp":true,"width":"6","collapse":false},{"id":"8f03e639.85956","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
or
[{"id":"c45993.1bd30e7","type":"inject","z":"5a245aa1.510164","name":"bad request","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":940,"wires":[["6b2ccd77.4da4cc"]]},{"id":"6b2ccd77.4da4cc","type":"function","z":"5a245aa1.510164","name":"simulate bad result from db","func":"msg.payload = [];\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":360,"y":940,"wires":[["ebc37340.ddfd9","af19c8b9.373f08"]]},{"id":"ebc37340.ddfd9","type":"ui_gauge","z":"5a245aa1.510164","name":"Available Hand Sanitizer Dispenser 1","group":"8b5cde76.edd58","order":3,"width":"6","height":"6","gtype":"wave","title":"Available Hand Sanitizer","label":"ml","format":"{{msg.payload[0].available}}","min":0,"max":"3000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"500","seg2":"1500","x":760,"y":940,"wires":[]},{"id":"af19c8b9.373f08","type":"debug","z":"5a245aa1.510164","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":730,"y":820,"wires":[]},{"id":"2385f349.ef9804","type":"inject","z":"5a245aa1.510164","name":"set level 1100","props":[{"p":"payload[0].available","v":"1100","vt":"num"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":320,"y":1020,"wires":[["ebc37340.ddfd9"]]},{"id":"1da1c840.e6bd6","type":"change","z":"5a245aa1.510164","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[{\"available\":0}]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":860,"wires":[["af19c8b9.373f08","ebc37340.ddfd9"]]},{"id":"90121f6c.ad8ee","type":"catch","z":"5a245aa1.510164","name":"","scope":["ebc37340.ddfd9"],"uncaught":false,"x":240,"y":860,"wires":[["1da1c840.e6bd6"]]},{"id":"8b5cde76.edd58","type":"ui_group","name":"","tab":"8f03e639.85956","order":1,"disp":true,"width":"6","collapse":false},{"id":"8f03e639.85956","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
But in long term may be worth rethinking the flow set up.
Thank you so much, it works! I know my flow if far from perfect, but I've been using node-red for less than a week for an IoT university project. Can't thank you enough, I really had no ideia how to go around this problem.
